geroq
Bridge stop work after reboot.
Wed Nov 02, 2005 11:54 am
I set up 2 ethernet cards in bridge and everything work fine,but when the system reboot the bridge don't work.I fix it with "/interface disable bridge1"
"/intreface enable bridge1".Sometimes bridge stop work when the MT is running.I use Mikrotik 2.9.2.
HarvSki
Wed Nov 02, 2005 4:18 pm
I have seen this happen with 2.8.xx (I think 26), then when I use 2.8.27/28 it is ok
Try upgrading your RouterOS to 2.9.6 or recreate the bridge.
geroq
Wed Nov 02, 2005 6:04 pm
I have installed 2.9.6 but the problem still exist.Here are my settings:
/ip address add address=10.10.1.1/24 interface=ether1
/ip address add address=10.10.1.2/24 interface=ether2
/interface bridge add disabled=no name=bridge1
/interface bridge port set ether1,ether2 bridge=bridge1
Is there something wrong?
Eugene
Forum Veteran
Forum Veteran
Thu Nov 03, 2005 10:23 am
IP addresses should be on the bridge, not on individual interfaces. (You can't have addresses from the same net on different interfaces).
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
geroq
Thu Nov 03, 2005 10:41 am
It is not important.I tried without any ip addresses and with ip address on bridge,but there is no change.Is it possible to be hardware problem,because when I disable and enable ether1 after reboot bridge start work?
aviper
Thu Nov 03, 2005 11:59 am
Did you try with other NICs? Are NICs with the same chipset or different. Sometimes NICs with different chipset crash eachother when they use a share IRQ.
HarvSki
Thu Nov 03, 2005 6:00 pm
Like Eugene says you must have the IP address bound to the bridge and none on the NIC
geroq
Thu Nov 03, 2005 6:57 pm
I have already done this but with no success.Any other ideas?
Eugene
Forum Veteran
Forum Veteran
Thu Nov 03, 2005 7:07 pm
Then it should be a hardware problem.
ddlan
Fri Nov 04, 2005 12:48 pm
enable NTP-Client und Netwatch, then the Bridge work after reboot :mrgreen:
mfg
Thomas Böttcher
Users browsing this forum: Bing [Bot], Google [Bot], jebz, solomon777, wichets, Znevna and 96 guests
