MUM Europe 2020
macsrwe
Forum Veteran
Forum Veteran
Brain Transplants
Tue Jun 14, 2011 1:24 am
I had a power problem blow up a RouterBoard. I have an up-to-date save and an up-to-date export for the board, and have another arriving soon. (I am temporarily running on a slower model board.) My question is, how best to perform the "brain transplant" from the old board to the new one?
I have performed this sort of operation manually in the past to add new routers to my network (usually between different models of board) by hand-editing export files, and it's not trivial to get right.
At first, I thought, "no problem, I'll just restore the backup from the old board because it's exactly the same model," but then I remembered some of the problems I have run into on the other units and got worried. For instance, I actually ended up changing the MAC addresses on the ports of one router because I forgot to edit them out of the export file (I never imagined I could just say "set the MAC address to XYZ" and it would just do it!) My next thought was, is this going to screw up my license or my software ID? Then, "what else am I going to reset that I'm not considering?"
Surely other people have to duplicate or move configurations. How do other people do it?
fewi
Re: Brain Transplants
Tue Jun 14, 2011 1:41 am
Sadly that's pretty much it - hand edit the file before importing into the other router.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
macsrwe
Forum Veteran
Forum Veteran
Tue Jun 14, 2011 1:51 am
OK, then… two things I already know I have to edit out are MAC addresses and software/license information. Is there anything else I should be warned to watch out for?
Belyivulk
Tue Jun 14, 2011 11:05 am
anything interface specific :)
Users browsing this forum: No registered users and 100 guests
