aprzybylski
Trunking between RB750G and RB250GS
Tue Jul 19, 2011 1:49 pm
Is it possible to configure the devices to obtain a configuration as shown? In particular, if I can all ports in RB750G used as a switch? It is possible to assign ip address?
fewi
Re: Trunking between RB750G and RB250GS
Tue Jul 19, 2011 5:04 pm
You can't assign untagged VLANs to ports on either device.
Get a proper switch, use a router on a stick approach.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
LukasSVK
Tue Jul 19, 2011 9:41 pm
Hello, untagged port (access port to vlan) in routerboard switch chip (except RB250GS) does not work. Your setup is possible only with another switch between RB750G and RB250GS.
L.
Users browsing this forum: sindy and 96 guests
