fabsoft
Get access to login/status page of hotspot's user from WAN
Thu Jul 21, 2011 11:30 am
Hi all,
i've a hotspot system with 2 interfaces, WAN and LAN in which the hotspot is installed.
in the WAN segment there are multiple PC used by secretaries who want get some information about the users of hotspot,
such remaining-uptime and expiring time.
Is there a way to access the login/status page from within the WAN to obtain these info ?
thanks in advance
Egate
Long time Member
Long time Member
Re: Get access to login/status page of hotspot's user from W
Sat Jul 23, 2011 10:29 pm
Probably the lan? Wan normally interne side.
Happy days. :-)
boomdv
Mon Jul 25, 2011 2:08 am
Hi all,
thanks in advance
Yes.you can do this by vpn.
fabsoft
Tue Jul 26, 2011 6:03 pm
Hi all,
thanks in advance
Do You mean a vpn like pptp tsattached to a bridge together with Hopot interface ?
i'll give it a try
fewi
Tue Jul 26, 2011 6:13 pm
The status page for a user can only be accessed by that user, if that's what you're asking for. You can't view someone else's status page.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
dssmiktik
Forum Veteran
Forum Veteran
Wed Jul 27, 2011 3:57 am
However, you may be able to use the API to hookup a web page to display stats. The server providing such page could be made accessible via the WAN.
Doug
Users browsing this forum: No registered users and 72 guests
