agenovez
SSID Lost After Backup
Thu Jul 21, 2011 5:50 pm
Greetings,
I have a strange problem with routerboard 411AH, lastest version Stable.
After I made a backup, all my ssids are missing on the interfaces :(
If somebody have the same problem would be great any help.
normis
Re: SSID Lost After Backup
Fri Jul 22, 2011 9:58 am
what do you mean by "made backup"? you loaded backup, or saved backup? you just clicked on "backup save" and in this moment lost SSIDs?
agenovez
Wed Sep 21, 2011 5:40 pm
Thank you for your Reply, I issued the file backup command, but nevermind, this is a problem about the mac of the interfaces, so I researched and found that actually can`t use the same backup on a different board with different wireless cards, so i issued the command "export" and change it manually.
Sorry for the delay, and again, thanks for your answer
Andres
Users browsing this forum: Bing [Bot], carlosdaff, gourgovind, ingdaka, xvo and 43 guests
