MUM Europe 2020
dancms
Add DHCP leases to address-list
Wed Jul 27, 2011 10:28 pm
I have seen some posts but still dont have a clear answer, is it possible to add dhcp leases dynamically to an address list with RADIUS or any other method?
Once again, straight DHCP, no hotspot, no pppoe.
Thanks!
-dan
fewi
Re: Add DHCP leases to address-list
Wed Jul 27, 2011 10:47 pm
The manual says no: http://wiki.mikrotik.com/wiki/Manual:IP ... er#Summary
Mikrotik-Address-List isn't listed as a valid Access-Accept attribute.
That said, it isn't listed in the full RADIUS client manual either. So give it a shot, try to send it back with a DHCP lease, and see what happens.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
astounding
Thu Jul 28, 2011 3:12 am
Just schedule a script to run periodically, something like:
/ip firewall address-list remove [/ip firewall address-list find list=foo];:local a;:set a [/ip dhcp-server lease find status="bound"];:local b;:for b from=0 to=([:len $a]-1) step=1 do={/ip firewall address-list add list=foo address=[/ip dhcp-server lease get [:pick $a $b] address]}
(Just replace "foo" with the name of the address list you want. WARNING: The above script deletes all list entries in the list, then adds new entries for each IP lease that is in the "bound" state.)
Wouldn't something like that work?
Aaron out.
dleo
Thu Dec 15, 2011 11:35 pm
Hi dudes, just rigth now I probe with:
 /ip dhcp-server lease add address-list=listExample mac-address=XXXXXXXXXX address=10.x.x.x
The result was, when the ip address is bound, dynamically it's add to address list.
Well, now I'm worried, with this setup, Will it consume a lot of recourses?
Thanks.
martini
Fri Dec 16, 2011 1:07 am
work without problem many years, no problem with any version (x86)
Dynamically added lease with address-list
sacitec
Thu Jun 16, 2016 9:44 pm
Hello everyone,
Don't know if this topic is still open, but in our network we are working with freeradius(daloradius web front-end) + mikrotik dictionary and it works like  charm; the only 'hack' you need  to do on dictionary attributes(MySQL dictionary table, under 'radius' database) is to change any Mikrotik field (already created) with 'Mikrotik-Address-List' field. This is the modification we made under daloradius core; if you use pure freeradius, you don't need this hack.
When you configure the user MAC auth, you need to set up the address list attribute as 'reply'; that's al, all dhcp-leases coming from DHCP-server (validated from freeradius) create a dynamic entry on your Mikrotik. Don't forget to load Mikrotik Dictionary; it's a valid argument. ( http://wiki.mikrotik.com/wiki/Manual:RADIUS_Client )
The freeradius argument is Mikrotik-Address-List.
Hope it helps, if you have any trouble please feel free to contact me.
Regards,
Ivan Reyes
SACITEC
Guderz1990
Wed Jan 04, 2017 7:53 am
Hi guys,
I would like to connect my pppoe clients to my radius server and also do the billing using daloradius (front end). When I add a profile to a user, the same credentials that would have been authenticating will seize to authenticate. Anyone who knows where I might be getting it wrong.
Thank you in advance.
Users browsing this forum: mandrade, shamet, Sob and 99 guests
