MUM Europe 2020
alireza6918
problem in PPPOE authentication
Thu Sep 08, 2011 7:45 am
hi
I used Mikrotik as a PPPOE server.
I created 2000 VLAN interfaces and made 1 PPPOE servers on each VLAN interface.
so I have 2000 PPPOE servers.
but when I put the Mikrotik in our network I received the following logs for many users and users couldn't connect.
Sep/07/2011 23:56:45 pppoe,debug,packet 15.3VLAN1197: rcvd PADI from 00:1F:A4:21:D1:B6
Sep/07/2011 23:56:45 pppoe,debug,packet session-id=0x0000
Sep/07/2011 23:56:45 pppoe,debug,packet service-name=
Sep/07/2011 23:56:45 pppoe,debug,packet host-uniq=0x610410
Sep/07/2011 23:56:45 pppoe,debug 15.3VLAN1197: dropping PADI: all services are busy
and for some other users I received the following:
Sep/07/2011 23:57:42 pppoe,ppp,info <pppoe-1>: terminating... - peer refused to authenticate
Sep/07/2011 23:57:42 pppoe,debug,packet 15.3VLAN173: sent PADT to 00:13:C4:B4:5A:40
Sep/07/2011 23:57:42 pppoe,debug,packet session-id=0x4c00
Sep/07/2011 23:57:42 pppoe,debug,packet relay-session-id=
Sep/07/2011 23:57:42 pppoe,ppp,debug <004c>: LCP lowerdown
Sep/07/2011 23:57:42 pppoe,ppp,debug <004c>: LCP down event in initial state
Sep/07/2011 23:57:42 pppoe,ppp,info <pppoe-1>: disconnected
does anyone know the problem?
proxy
Re: problem in PPPOE authentication
Sat Sep 17, 2011 11:50 pm
let us se one of the pppoe server config
alireza6918
Mon Sep 19, 2011 8:55 am
here it is:
/interface pppoe-server server
add authentication=pap default-profile=default disabled=no interface=VLAN2101 keepalive-timeout=10 max-mru=1454 max-mtu=1454 max-sessions=1 mrru=disabled \
one-session-per-host=no service-name=service1
/ppp profile
set default change-tcp-mss=no dns-server=192.168.11.4,192.168.11.10 local-address=192.168.16.5 name=default only-one=default remote-address=pool1 \
use-compression=default use-encryption=default use-ipv6=yes use-mpls=default use-vj-compression=default
stefanosp
Sun Feb 24, 2013 12:58 pm
alireza6918, did you solved the problem? I have the same one!
TIA
RB951G-2HnD
mac86
Sun May 05, 2013 4:49 am
same problem too :-(
ronix
Sun May 05, 2013 7:59 am
please can you tell us about the advantage of having 2000 vlans & pppoe servers ??
rikw22
Fri May 24, 2013 3:45 pm
Are you using LEVEL 4 license?
mac86
Thu May 30, 2013 2:32 pm
6, in my case.
dleo
Wed Apr 29, 2015 3:13 pm
The problem is you have max-sessions=1, remove or evaluated because that allow just one pppoe session.
Regards.
David L.
Users browsing this forum: No registered users and 88 guests
