MUM Europe 2020
alfrqan
Setup 2WANS+2LANS with same IP range??
Wed Sep 21, 2011 12:40 pm
HI
i want to Setup 2WANS+2LANS with same IP range for LANS example :192.168.1.0/24
how can i do it??
i already setup my wans to ppoe
Thankx
cbrown
Trainer
Trainer
Re: Setup 2WANS+2LANS with same IP range??
Wed Sep 21, 2011 9:21 pm
Why do you want to use the same IP range?
Did you want a WAN for each LAN or both WANs load balanced for both LANS?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
alfrqan
Thu Sep 22, 2011 1:21 pm
LOAD BALANCE
cbrown
Trainer
Trainer
Thu Sep 22, 2011 2:20 pm
Alright, why do you want to use the same IP Range?
C.Brown
alfrqan
Fri Sep 23, 2011 7:52 am
because i want to link my hotspot with external web server so they can use it all of my clients!
fewi
Fri Sep 23, 2011 8:00 am
That explanation makes no sense whatsoever. Having an external web server for a Hotspot has nothing to do with duplicate IP ranges (which is something you simply shouldn't do).
Please provide a network diagram, and a detailed explanation of what you're trying to do. By that I mean the goal you're trying to accomplish, not how you think you'd have to go about it to get there.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Users browsing this forum: blindber and 111 guests
