arpadffy
default route choice based on throughput
Sat Oct 08, 2011 6:07 pm
I have some trouble choosing the default route between two routes.
The choice based on "distance" works perfect if the default route with lower distance dies - automatically with the another route with higher distance takes over.
My problem is that my default route rarely dies, just drop the throughput -that is measurable with ping times over 1300ms.
Is there any script or another smart solution how to detect those events and in such cases automatically use a route with higher distance instead?
Thank you.
Regards,
Z
siscom
Re: default route choice based on throughput
Sat Oct 08, 2011 8:44 pm
If you consider that a ping with a timeout of over 1 second (1000 millisecconds) is a good metric for you, you can use the Netwatch tool.
This is quite useful but it's main limitation is that the threshold is only 1 sec or above, and only in 1 sec increments.
Link - http://wiki.mikrotik.com/wiki/Netwatch
Rgds,
Mark.
arpadffy
Sun Oct 09, 2011 7:43 am
Thank you.
This is exactly what I was looking for.
Regards,
Z
Users browsing this forum: hermeson, irakliskirlis, McSee, PiGeonCZ and 133 guests
