jandafields
USB Dial-up Analog Modem
Mon Oct 17, 2011 5:52 pm
Does Mikrotik support USB Dialup Analog modems? I see how to use a serial modem, but I'm talking specifically about USB connected modems (NOT 3G and NOT DB9 SERIAL).
I realize that Mikrotik would use a driver to then access the modems like a serial device, but I am unable to find any type of compatibility list anywhere for these.
Does anyone have experience with working USB modems or know of an official answer?
Thank you.
jandafields
Re: USB Dial-up Analog Modem
Sun Oct 23, 2011 11:27 pm
In case anyone else has this need in the future:
I contacted mikrotik support and they said it could not be done, no USB modems are supported.
So, I tried it myself with a USB modem and it works GREAT! Absolutely no problems found yet.
I don't know why they would say it isn't possible when it does in fact work, and is such a great feature.
joecoolzxc
Thu Oct 25, 2012 11:46 pm
can you tell me the brand of the dialup modem and maybe where to find it
jandafields
Fri Oct 26, 2012 2:10 am
I use the USR 5637. It's a great modem.
dcs
Mon Oct 29, 2012 6:17 pm
Hi:
Can you provide a bit more detail on your hardware config and OS?
I'm interested in something like this using a very small form factor and inexpensive box with two eth ports. Preferably, I'd like to have the modem built-in.
Thanks.
joecoolzxc
Thu Nov 01, 2012 5:25 pm
Hey i bought one of the USR 5637, i am trying to dialing into the Mikrotik but failing to negoiate is there any special settings, i created a ppp-in server and matching user
jandafields
Thu Nov 01, 2012 6:20 pm
Hi:
Preferably, I'd like to have the modem built-in.[/i]
There aren't any routerboards with a built-in modem.
jandafields
Thu Nov 01, 2012 6:22 pm
I've never tried dialing IN to the Mikrotik. I use mine to dial OUT of the Mikrotik.
Users browsing this forum: Google [Bot], joshfinlay, mducharme and 47 guests
