drzen
Windows 2008 Virtual IP and hotspot
Thu Oct 20, 2011 3:36 pm
anyone have experiences with windows 2008 terminal service Virtual IP and mikrotik hotspot functionality?
Thanks in advance
v.
(Rate my posts? If you want... no pressure...)
navidrasi
Re: Windows 2008 Virtual IP and hotspot
Thu Oct 27, 2011 1:56 pm
hi
i had installed RDS virtual ip and mikrotik
i had some difficulties with ARP and some Problem with DHCP
but i had finally get it to work
tel me if i can help you ?
drzen
Thu Oct 27, 2011 1:59 pm
Any help is good.
DHCP work fine... seem an ARP problem.
v.
SurferTim
Thu Oct 27, 2011 3:23 pm
Try disabling the 1:1 NAT on the hotspot. That will arp poison the localnet if you don't disable it.
/ip hotspot
print
set X address-pool=none
drzen
Thu Oct 27, 2011 3:27 pm
/ip hotspot
print
Just done! But no effect.
TS clients receive the second ip address but when I try to surf the web I can not (page expired).
If I disable hotspot all go right.
v.
SurferTim
Thu Oct 27, 2011 3:31 pm
/ip hotspot
print
v.
No effect? What are you trying to do? Windows 2008 computer won't ping? Can't ping from another localnet computer? Can't ping from the router? Can't ping from the internet?
drzen
Thu Oct 27, 2011 3:42 pm
/ip hotspot
print
v.
Sorry for the edit ;-)
TS clients receive the second ip address but when I try to surf the web I can not (page expired). Pings go right (to local network machines).
v.
SurferTim
Thu Oct 27, 2011 3:51 pm
OK. Check here and insure all is going ok. This is also where you can see the 1:1 NAT work.
/ip hotspot host
The hotspot will stop almost all port services until you login with the web browser on that computer, or bypass the ip/mac in
/ip hotspot ip-binding
add address=x.x.x.x type=bypassed
Same works for the mac address if the ip might be different.
Users browsing this forum: boxxed, eguun, mkx and 95 guests
