MUM Europe 2020
InoX
340mbps with bonding
Fri Oct 21, 2011 4:21 pm
Today i have bonded 2 links with SXT. Only 235mbps UDP is generated, the rest is real trafic.
Chupaka
Re: 340mbps with bonding
Mon Oct 24, 2011 1:16 am
what kind of bonding is it?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rado3105
Sun Sep 14, 2014 10:22 pm
Does anybody have active working bonding?
Chupaka
Mon Sep 15, 2014 12:06 pm
sure
rado3105
Sat Sep 20, 2014 8:13 am
sure
what kind? ospf, eoip(what mode of balancing balance-rr, xor..)? which is best for 2 wireless nv2 links
Chupaka
Mon Sep 22, 2014 12:55 pm
ethernet, balance-xor
-xor, I think. definitely not -rr
victors0991
Sat Aug 05, 2017 7:01 pm
Ospf can double bandwidth?
InoX
Mon Aug 07, 2017 3:56 pm
You have already get an answer. If you don't understand the way that ospf works, maybe you should learn.
Users browsing this forum: arfcz, crosswind, marek263, PwFactor and 165 guests
