n21roadie
493Ah’s strange loss of connectivity + ospf issue
Mon Oct 24, 2011 4:20 pm
I have a routed network no bridging and in my network which is 100% MT,
I noticed with just two 493Ah boards,
One (running OS 5.6) has/had on test at the moment was reporting every few days loss of ospf route to a ptp link on one port /30 and after a while the 493 would lose connectivity but strange login from the wlan side to the ptp 433ah and winbox would display no connectivity (R) on Ethernet port 1 which is also POE (24volts), replaced the rj45 connectors both ends but still after a few days ospf + lose connectivity?
Second was running OS 3.30 had a sudden loss of connectivity to the wlan side of a ptp, after several reboots and checking still no connectivity so I upgraded this 493 to 5.6 and still no luck, so I just disabled wireless package as it’s not used in the 493 and would you believe connectivity issue disappeared – strange as I always thought that disabling un-used packages would just improve performance but in this case it solved a connectivity issue, it remains if disabling wireless on the first one will solve the ospf issue.
N21roadie,
Network 100% MT for Now?
mrz
Re: 493Ah’s strange loss of connectivity + ospf issue
Mon Oct 24, 2011 4:26 pm
What OSPF configuration you have on wireless links. Is it set to NBMA?
n21roadie
Mon Oct 24, 2011 5:27 pm
Using 10.X.X.29/30 for wlan and ethernet 10.X.X.33/30 then in OSPF network backbone= 10.X.X.28/30 and 10.X.X.32/30
N21roadie,
n21roadie
Tue Oct 25, 2011 3:25 pm
Not using NBMA should it be used?
N21roadie,
mrz
Wed Oct 26, 2011 9:28 am
Yes, it should be NBMA.
Users browsing this forum: Feche, maigonis, MSN [Bot] and 214 guests
