omidh
Inter Vlan Routing
Wed Nov 16, 2011 2:46 pm
hi
how can we route between vlans on L3 like cisco.
for example i created Vlan 200 and 201 under ethernet 1 and set ip address 172.16.1.1 on vlan 200 and
172.17.1.1 on vlan 201.
the problem is that i cant ping interface vlan 201 from vlan 200.
what should i do?
thanks
muxure
Re: Inter Vlan Routing
Wed Nov 16, 2011 3:05 pm
When configured correctly, VLANS should just route.
Please post your config.
omidh
Wed Nov 16, 2011 3:51 pm
just simply add vlan 700 and 704 under eth 2
and set ip address for each one
thats all
any extra configuration is needed?
[admin@KavooshNet] > interface print
 #     NAME                                       TYPE             MTU   L2MTU
0     ether1                                     ether            1500  1526
1  R  ether2                                     ether            1500  1522
2  R  ether3                                     ether            1500  1522
3  R  Datacenter                               vlan             1500  1518
4  R  Parse                                      vlan             1500  1518
[admin@KavooshNet] > interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME                  MTU   ARP        VLAN-ID INTERFACE
0 R  Datacenter            1500  enabled  700     ether2
1 R  Parse                 1500  enabled    704     ether2
[admin@KavooshNet] > ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   172.16.2.23/24     172.16.2.0      172.16.2.255    ether3
 1   172.16.1.1/30     172.16.1.0      172.16.1.255     Datacenter
 2   172.17.1.2/29     172.17.1.0      172.17.1.255     Parse
Feklar
Wed Nov 16, 2011 4:46 pm
The problem is you have the same subnet on two routed interfaces. That's why it can't route between Parse and Datacenter. Make sure they are on different subnets, and as long as there are no firewall rules preventing it, they will route just fine.
http://www.aelius.com/njh/subnet_sheet.html
Users browsing this forum: marcosvales, Znevna and 185 guests
