dan_99503
ARP connectivity problem
Tue Nov 29, 2005 2:27 pm
I just replaced an existing v 2.8.26 router with a faster system running 2.9.8 w/4port NIC (both PC based). It seemed to work ok but I started running into very strange intermittent problem with being able to reach various IP addresses that were local and had entries in the ARP table. The weird part is that the Mikrotik was the only unit that couldn't talk to them when it happened. It could however receive pings back from IP addresses just above and below the one in question.
The units are configured the same and are doing some basic routing (static) with some firewall and have NAT rules for several private networks. They also have P2P mangle and queue rules to limit them. I was going to implement a web-proxy on the new unit which was the reason for the upgrade.
I have temporarily wrote a simple script which seems to make the problem not manifest itself. The script just removes an ARP entry from the table every 2 seconds. This entry is immediately repopulated since it happens to be a high traffic server.
I can think of a reason why this would be happening unless the Mikrotik or the Switch are doing something strange.
(Fictitious IP addresses were used to protect the innocent)
Internet:(12.12.12.192/29 subnet)
|12.12.12.193 (Gateway)
| 12.12.12.194/29
Mikrotik Router
| 12.12.12.129/27
Ethernet Switch
rest of network (servers routers etc).
All of these tests were run from within the Winbox on the router (12.12.12.129) and a PC that is connected through the switch on the other side (12.12.12.146). The unit performs normally for a while and then starts having problems and then will start working again after a few seconds or minutes.
On the MIkrotik I can start a ping to 12.12.12.131 (server, reliable). It will ping for while and then stop getting a response, the ARP entry is still in the table and the server is still available to everyone else on the network. If I wait then it will usually start working again after a few seconds or possibly 2-5 minutes.
While it is failing to get a response from 12.12.12.131 I am still able to ping 12.12.12.130 and 12.12.12.131. When checking from the network internally (from a PC at 12.12.12.146) at the same time the Mikrotik router is having the problem everything is working well except traffic to the two Mikrotik router interfaces. Sometimes only the external interface on the Mikrotik router will fail to respond to pings while the Internal one keeps working.
This is already a strange problem but it doesn't stop here. I noticed that if the problem started and I remove an entry from the ARP table on the Mikrotik then it will start working normally (passing traffic between interfaces for all devices on the network and not dropping pings).
I wrote a script that removes the entry for the server at .131 every two seconds and it seems happy with it. It hasn't dropped any pings since (not even to the server @ 131). :shock:
Does anyone have any experience with anything like this? I think it might be either the Mikrotik router or possibly the switch is doing something very strange. Any takers?
- Dan
csickles
Tue Nov 29, 2005 11:48 pm
Check this one out...
I had an issue in which a "Dumb" 8 port switch got a cable connectd back to its self.. IE a cable came from the backbone switch to this dumb device. than a second cable was pluged into the domb device and looped back to its self..
This TOTALY Pi$$ed off the switching fabric !!!!
The backbone switch and the dumb device both thaught they owned the path to the MAC address of the entire network and they advertised as such.
This Completely PI$$ed off my router...
It behaved similarly to what you ere seeing only it would come and go as the MAC tables would get flushed by the switches ...
After the loopback was removed and the switches reset (power) all was well...
What a pain in the #$#@$@#$ that one was...
Just some thing too think about..
Craig
dan_99503
Wed Nov 30, 2005 12:04 am
Craig,
Thanks for the input, I will double check and see if that is what we are running into.
Thanks,
- Dan
Diganet
Wed Nov 30, 2005 12:16 am
How is the port utilization when this is occuring?
Regards
HP
dan_99503
Wed Nov 30, 2005 12:43 am
Utilization drops to around 5-6KB/sec each direction when the problem occurrs.
I just found out from the field tech that he is not sure they disconnected the old Mikrotik router from the LAN segment! I am having them check that now as that could cause major problems 8(.
- Dan
dan_99503
Wed Nov 30, 2005 10:41 am
It is confirmed. The problem is that they didn't disconnect the other router from the LAN segment when the installed the new one *sigh*. The problem is now resolved.
- Dan
Users browsing this forum: No registered users and 96 guests
