MUM Europe 2020
Iceog
Gateway timeout with proxy and routing
Thu Dec 08, 2011 3:32 pm
Welcome,
I know there are many post about my problem , but i did not find solution.
If I turn on redirecting 80 port to 8080 i get gateway timeout. The problem did not exist , when the routing wasnt set.
Here is my specification:
IP Adress
0 ;;; hotspot network
address=192.168.100.1/23 network=192.168.100.0 interface=ether2
actual-interface=ether2
1 address=172.16.1.2/30 network=172.16.1.0 interface=ether1
actual-interface=ether1
IP ROUTE
0 A S dst-address=0.0.0.0/0 gateway=172.16.1.1
gateway-status=172.16.1.1 reachable ether1 distance=1 scope=30
target-scope=10
1 ADC dst-address=172.16.1.0/30 pref-src=172.16.1.2 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
2 ADC dst-address=192.168.100.0/23 pref-src=192.168.100.1 gateway=ether2
gateway-status=ether2 unreachable distance=0 scope=200
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=no
/ip firewall mangle
add action=accept chain=output disabled=no dscp=4
add action=redirect chain=dstnat disabled=no dst-port=80 protocol=tcp \
to-ports=8080
"place hotspot rules here" disabled=yes
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Thanks in advance for any help.
P.S. Sorry for my english :)
Iceog
Re: Gateway timeout with proxy and routing
Thu Dec 08, 2011 4:00 pm
I note that , there on firewall/connections i get
Src. Address : 172.168.1.2
Dst. Address : 80.48.169.1 (www.orange.pl) - allowed on proxy server. For testing rest have deny
TCP State : Syn sent
Iceog
Wed Dec 14, 2011 12:41 pm
I just solved the problem by adding 192.168.100.1 as pref.src in route rule.
 0 A S  0.0.0.0/0          192.168.100.1   172.16.1.1                1
dasiu
Trainer
Trainer
Wed Dec 14, 2011 1:38 pm
If it was the solution - then the 172.16.1.1 router has very strange NAT rules :).
Iceog
Wed Dec 14, 2011 1:53 pm
No jest to dość skomplikowane :)
Thanks again,
Topic can be closed
dasiu
Trainer
Trainer
Wed Dec 14, 2011 1:59 pm
Yeah, the topic can be closed now :)
Taa, po tym "www.orange.pl" też wywnioskowałem, że Waść z Polski być musisz :).
Pozdrawiam! :)
Users browsing this forum: antonme, Bing [Bot], MSN [Bot] and 118 guests
