Iceog
Clients can access to internet, but router cant.
Tue Dec 13, 2011 2:54 pm
Welcome,
I have problem with access to the internet from my router. When i try ping ex. http://www.google.com or 173.194.66.106 in traceroute i get :
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; hotspot network
     192.168.100.1/23   192.168.100.0   ether2
 1   172.16.1.2/30      172.16.1.0      ether1
Route
 0 A S  0.0.0.0/0                          172.16.1.1                1
 1 ADC  172.16.1.0/30      172.16.1.2      ether1                    0
 2 ADC  192.168.100.0/23   192.168.100.1   ether2                    0
If You need more information pls. post.
P.S. I have searched solution earlier:)
P.S.2 . Sorry for my English :)
perspetolis
Re: Clients can access to internet, but router cant.
Tue Dec 13, 2011 8:10 pm
please send your trace photo.
your info does't complete.
Mohsen Farahani
MTCNA-MTCWE-MTCTCE
http://www.ipsolution.ir
Iceog
Wed Dec 14, 2011 10:52 am
Thank you for your interest in this subject
I hope you mean this:
Trace from router
[admin@MikroTik] > tool traceroute 173.194.66.106
 # ADDRESS                                 RT1   RT2   RT3   STATUS
 1 172.16.1.1                              1ms   1ms   1ms
 2 0.0.0.0                                 0ms   0ms   0ms
 3 0.0.0.0                                 0ms   0ms   0ms
 4 0.0.0.0                                 0ms   0ms   0ms
Trace from client going like this
->192.168.100.1
->172.16.1.1
->google.com
SurferTim
Wed Dec 14, 2011 12:27 pm
Can you post the info from "/ip firewall nat"?
Iceog
Wed Dec 14, 2011 12:38 pm
Thank You a lot for help. I just solved the problem by adding 192.168.100.1 as pref.src in route rule.
 0 A S  0.0.0.0/0          192.168.100.1   172.16.1.1                1
Once again Thanks :)
SurferTim
Wed Dec 14, 2011 12:45 pm
That solution would indicate your masquerade or srcnat is incorrect.
You probably have this
chain=srcnat action=masquerade src-address=192.168.100.0/24
That is the nat rule added by the hotspot.
You need something like this:
add chain=srcnat action=masquerade out-interface=ether1
Iceog
Wed Dec 14, 2011 1:17 pm
I don't use masquerade.
I want to export my firewall nat rules , but its return only 2 of 9 rules.
SurferTim
Wed Dec 14, 2011 1:27 pm
Then I presume you have the 192.168.100.0/23 net routed back to the router from the proxy server. That would make sense.
Iceog
Wed Dec 14, 2011 1:46 pm
:) Once again Thank You a lot :)
dasiu
Trainer
Trainer
Wed Dec 14, 2011 3:58 pm
Yeah, and that the router with proxy server (172.16.1.1) does also masquerading for 192.168.. addresses only :) - that was probably the problem, why the RB couldn't connect, as it was not NATted outside.
<lang=pl>Iceog - dzięki za "gotowość do pomocy" :) Ale już nie przesadzajmy z nabijaniem sobie darmowych punktów :).</lang=pl>
Users browsing this forum: No registered users and 75 guests
