robertpenz
/store add --> input does not match any value of type
Wed Dec 14, 2011 5:12 pm
Hi!
I'm trying following on an 450g with 5.9 and 5.11 software:
> /store disk print detail
Flags: S - system
 0 S name="system" total-space=520192KiB free-space=483996KiB status=ready
 1   name="micro-sd" total-space=7639928KiB free-space=7491668KiB status=ready
> /store print detail
Flags: X - disabled, A - active
> /store add disabled=no disk=micro-sd name=proxy type=web-proxy
If I press ? for the type I get any empty list:
[admin@zirlstrm-dist-3] > /store add disabled=no disk=micro-sd name=proxy type=
Type ::=
Is this a bug?
janisk
Re: /store add --> input does not match any value of type
Wed Dec 14, 2011 5:17 pm
go to store disk, most probably you have to have it formatted, then it will become available
robertpenz
Thu Dec 15, 2011 9:59 am
I formated it and than I got the status "ready" otherwise it would be not ready. I also did a check-drive. But I'll try an other microsd card, maybe it is incompatible.
Users browsing this forum: Baidu [Spider], nostromog and 71 guests
