Jeeves
Converting config backups to readable data
Mon Dec 19, 2011 10:20 am
My RouterOS box became unreachable via the shell. (I can login, but don't get a command prompt.) I do have a backup of the config, but that seems to be binary data. Is there any known way to convert that to a readable config?
Jeeves
Re: Converting config backups to readable data
Mon Dec 19, 2011 12:19 pm
Mikrotik support has let me know that you can't convert backup files to a readable config. What a sucky and useless feature, this backup.
doush
Long time Member
Long time Member
Mon Dec 19, 2011 12:38 pm
backup your config script as below
/export file=mybackup.rsc
this will let you to backup in a readable format.
Users browsing this forum: Bing [Bot] and 71 guests
