marioclep
Trainer
Trainer
New MikroTik products?
Wed Dec 21, 2011 4:41 pm
I was searching for new MikroTik products, and I found this:
RB411L: http://download.routerboard.pl/rb411L.pdf
RB433GL: http://download.routerboard.pl/rb433GL.pdf
R5-SHPn: http://download.routerboard.pl/R5SHPn1.pdf
Are these products available?
Regards
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
honzam
Re: New MikroTik products?
Wed Dec 21, 2011 5:50 pm
Nice.
When available?
Why all the new products (711, 411L, SXT, Omnitik, 433GL) do not have a serial port? It was very helpful!
LAN, FTTx, Wireless. ISP operator
honzam
Sun Dec 25, 2011 2:10 pm
In datashed je wrote rb411L have Voltage monitor http://routerboard.com/pdf/366/rb411L.pdf
But there is - Voltage monitor NO http://routerboard.com/RB411L
What is wrong?
normis
Tue Dec 27, 2011 8:11 am
sorry, but there is no voltage monitor on RB411L, we will fix the PDF
nz_monkey
Tue Jan 10, 2012 4:39 am
Hi Normunds,
Can someone please update http://wiki.mikrotik.com/wiki/Manual:Ma ... uterBoards with the MTU supported by the 411L and 433GL.
Thanks!
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
honzam
Re: 411L show voltage
Thu Jan 19, 2012 12:12 pm
Hello Normis, I have there RB411L and show voltage. How is this possible?
normis
Thu Jan 19, 2012 12:17 pm
is that correct voltage? :) if not, probably we need to remove the menu, because there is no voltage monitor hardware on this device.
honzam
Thu Jan 19, 2012 12:24 pm
We dont have 3000Volts :) It is powered by 9V. You can remove field in 5.12.
Mark
Users browsing this forum: arsalansiddiqui, Baidu [Spider], Lifz, llag, nocivo, saathiyabneha and 72 guests
