krisan
RB411 is unable to connect to ubiquiti powerbridgeM5
Fri Dec 23, 2011 2:10 pm
I bought a powerbridgeM5 which i want to use as AP to link two offices together. I configured the PBM5 as the AP and on the other end i used mikrotik RB411 as my CPE which is also 5Ghz antenna. When i scanned the network i could see the SSID of the powerbridgeM5 AP but cannot connect to it.
Can some one tell me if there is anything i am doing wrong?
Your response will be greatly appreciated.
normis
Re: RB411 is unable to connect to ubiquiti powerbridgeM5
Fri Dec 23, 2011 2:25 pm
disable airmax, as that's a protocol that only ubnt devices can use.
siscom
Sat Dec 24, 2011 3:19 am
And you have to disable both Nstreme and/or NV2 on the Mikrotik side too.
Rgds,
Mark.
krisan
Wed Dec 28, 2011 8:56 pm
Thank you guys very much for your response.
I still have a problem locating where to disable the airmax on the device. please tell me where i can locate it on the radio device.
Awaiting your response.
siscom
Wed Dec 28, 2011 10:32 pm
I'd look for that info on the ubnt site if I were you :D . They have a forum too.
Since this is a MikroTik user forum, management look dimly upon ubnt support issues/replies made here.
Rgds,
Mark.
Users browsing this forum: 8577, aysan, BillyVan, Google [Bot], MSN [Bot], poduck and 83 guests
