Bikes
LOST LICENSE AFTER UPGRADE
Mon Jan 02, 2012 6:38 pm
I upgraded my Level 6 Routeros running on an Intel x86 system from version 3.22 to version 5.9 via winbox and it lost its key. I have tried downgrading to 3.28 and it has refused. What do I do to restore my license?
normis
Re: LOST LICENSE AFTER UPGRADE
Tue Jan 03, 2012 8:11 am
Other users can't help you get your key back, this is a user forum. Please email MikroTik support to get help with licenses.
lordiceman
Wed Jan 04, 2012 11:09 pm
when i lost my licence, this is what i did:
Sign up for mikrotik.com, after registration you will receive by e-mail password to login.
Click (top left in the Account) - Select - Request key - Import key from MK - System - License - Import key
If all goes OK, go back to Account - Click on - work with keys - select virtual folder (for me bgslevi-marsl) - displays your keys (and here comes the part that I just noticed by chance), selecte key (the tiny letters), then again WinBox - System - License - (click) - Paste key. MK will reboot and everything goes ...
Bikes
Thu Jan 05, 2012 1:33 pm
Thanks Normis, I also wrote Mikrotik and I have got a reply. I am following it up.
Thanks lordiceman, I alerady have an account but I cant find any "request key" on my account page. I can only find "request key from another account" at the bottom left corner of my account page.
normis
Thu Jan 05, 2012 3:33 pm
Those are the same thing
lordiceman
Thu Jan 05, 2012 5:23 pm
yup, just go there and enter your software id or the key file
and btw i lost my key the way you did, upgrading from 3.x to 5.x, after that i rather upgraded from 3.x to 4.17 to 5.11 on the rest of routerboards and it went well
Bikes
Tue Jan 10, 2012 12:42 pm
Thanks a million. When I was almost about to loose patience with mikrotik support for replacement key and decided to try out this option they sent me a replacement key. Its perfect.
masterkomas
Mon Jul 15, 2013 3:36 pm
@all and Mikrotik,
Am having the same problem with my RouterOS. My routeros network was not browsing. So i removed the access points and connected to a separate switch and it browsed. so, it was confirmed that the routeros was the problem. i formatted it with my routeros software before which i backed up the settings. at the end of it i restored the setting. the problem now is how do i get back my license. am told as long as you didn't format it with a non-mikrotik software you can always get back your license.
i need help.
thanks at all.
Users browsing this forum: excession, inteq, ntrits, RiFF, seelawut and 147 guests
