arjuneu
Radius Problem
Thu Jan 12, 2012 7:34 am
I have having the radius accounting problem. I have attached the file. Please someone suggest me something.
SurferTim
Re: Radius Problem
Thu Jan 12, 2012 12:33 pm
Try increasing the radius timeout value. It helped me.
/radius
print detail
set 0 timeout=2s
arjuneu
Re: Radius Problem
Thu Jan 12, 2012 2:16 pm
will try that...thanks.
tyronzn
Re: Radius Problem
Thu Jan 12, 2012 5:00 pm
how is your radius configured between router and radius server?Are you using NAT or does the router authenticate to the radius server directly?
If using NAT make sure your router is forwarding Accounting packets to the radius server UDP 1813
arjuneu
Re: Radius Problem
Thu Jan 12, 2012 6:10 pm
/radius
print detail
set 0 timeout=2s
This doesn't work for me...
arjuneu
Re: Radius Problem
Thu Jan 12, 2012 6:11 pm
I am using Usermanager. That means I'm not using NAT.
tyronzn
Re: Radius Problem
Thu Jan 12, 2012 6:33 pm
post a copy of your hotspot config so i can take a look
/ip hotspot export
arjuneu
Re: Radius Problem
Fri Jan 13, 2012 6:10 pm
/ip hotspot export
[admin@ACE] > ip hotspot export
# jan/13/2012 21:51:31 by RouterOS 5.11
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=ACE http-proxy=0.0.0.0:9090 login-by=http-chap,http-pap name=\
default nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=received \
radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=yes
/ip hotspot user profile
set default advertise=no idle-timeout=15m keepalive-timeout=5m name=default open-status-page=always shared-users=1 \
status-autorefresh=5s transparent-proxy=yes
add advertise=no idle-timeout=15m name=hotspot open-status-page=always shared-users=1 status-autorefresh=5s \
add advertise=no idle-timeout=15m name=sulav open-status-page=always rate-limit=8k/16k shared-users=1 status-autorefresh=5s \
/ip hotspot profile
add dns-name=ace.net.np hotspot-address=0.0.0.0 html-directory=ACE http-proxy=0.0.0.0:9090 login-by=http-chap,trial name=\
hsprof1 nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=1m \
split-user-domain=no trial-uptime=5m/4w2d trial-user-profile=hotspot use-radius=yes
/ip hotspot
add disabled=no idle-timeout=5m interface=LAN keepalive-timeout=5m name=HS-Server profile=hsprof1
/ip hotspot ip-binding
add address=10.5.50.2 disabled=no mac-address=00:C0:26:69:A1:26 type=bypassed
add address=10.5.50.3 disabled=no mac-address=00:18:F8:84:05:8A type=bypassed
add address=129.75.168.1 disabled=no mac-address=F4:EC:38:C9:1B:32 type=bypassed
add address=129.75.168.2 disabled=no mac-address=B0:48:7A:CA:4A:1A type=bypassed
add address=129.75.168.125 disabled=no mac-address=00:C0:26:69:A1:26 type=bypassed
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept comment="Allow hotspot users to ping for troubleshooting purposes" disabled=no protocol=icmp
arjuneu
Re: Radius Problem
Fri Jan 13, 2012 6:12 pm
# jan/13/2012 21:56:42 by RouterOS 5.11
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=ACE http-proxy=0.0.0.0:9090 login-by=http-chap,http-pap \
name=default nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=received \
/ip hotspot profile
/ip hotspot
Users browsing this forum: Bing [Bot] and 77 guests
