prawira
Trainer
Trainer
3G Modem Stick recognize problem
Tue Jan 17, 2012 5:58 pm
Hi All,
I have RB751U-2HND plus 3G Modem Stick SpeedUP SU-8650U
The modem is detected under /system resource usb but not under /port
[admin@Test Unit] > /sys reso usb pr
# DEVICE VENDOR NAME SPEED
0 1:1 RB400 EHCI 480 Mbps
1 1:5 USB Modem USB Modem 480 Mbps
[admin@Test Unit] > /port pr
Flags: I - inactive
# NAME CHANNELS USED-BY BAUD-RATE
[admin@Test Unit] >
or under winbox as follow :
Is it my 3G Modem stick problem or ROS problem or other ?
TIA
Paul
adriand
Re: 3G Modem Stick recognize problem
Mon Jan 23, 2012 3:43 pm
I'm having the same problem with 751U-2HnD
I've tried 3 different 3G USB Sticks
Huawei E173 from Orange
Huawei K3765 from Vodafone
ZTE MF190
Those sticks are listed in supported hardware but not shoing up in "/port print".
Thanks.
dunga
Wed Jun 27, 2012 3:48 pm
Having the same issues,
I am having some issues regarding connecting with this modem, haier HSDPA data card. It will be seen in the /system resources, but could not be seen in the interface(ppp-out).
Is mikrotik not supporting this modem so that I can know what to do.
Users browsing this forum: MSN [Bot] and 122 guests
