nuskope
Simple Queue time issue.
Wed Jan 25, 2012 1:39 am
hi guys.
> V5.7 on X86
I am having an annoying issue with Simple Queue times.
the rules are as follows
Q1 - 15:00:00-23:59:59
Q2 - 00:00:00 - 01:30:00
(rule to run from 3pm-1:30am)
my issue, it swaps ok from Q1-Q2 but then when the time expires on Q2 it keeps the rule running, untill... i log in to winbox and click on the rule.. then, it turns off. just by 'refreshing' i guess.
Any advice?
brandonrossl
Re: Simple Queue time issue.
Wed Jan 25, 2012 7:23 pm
I think you might need a rule from 1:30-15:00 or else nothing will happen.
nuskope
Fri Jan 27, 2012 1:49 am
i don't want anything to happen :P
thats the plan..
IN theory if i add 'another' rule with just the time and the packet mark it will probably swap over but that seems s little off as the existing rules should work and not need a 'off time' rule...
any of the big lads have any ideas?
brandonrossl
Fri Jan 27, 2012 5:30 pm
I'm pretty sure they're triggered on start, so since you don't have a rule set for it to return to normal (whatever normal is) it doesn't have anything to trigger so it keeps on doing what it was doing.
Users browsing this forum: No registered users and 94 guests
