junglist00
Multiple PPPOE clients
Sat Feb 04, 2012 5:49 am
New to using mikrotik , have been thru forum have not seen answers related to this question.
Is it possible to configure mikrotik 750GL to connect to 2 separate pppoe connection ...
basically the setup is like this ... 1 pppoe connection to ISP 1 , bonded (2) pppoe connected to ISP 2 ... connection to ISP 1 connects , however trying to get ISP 2 to connect fails ... would like to know if this setup is possible and if so how is it accomplished.
huntah
Re: Multiple PPPOE clients
Sat Feb 04, 2012 10:40 am
This topic is coverd very good in foroum.
Just use a search engine...or wiki
You are looking for: PCC (http://wiki.mikrotik.com/wiki/Manual:PCC)
search for: 2wan, multiple wan, multiple ISP
You'll find it with no problem..
mistry7
Sat Feb 04, 2012 12:29 pm
do you won't to connect more than one PPPoe Connection to a DSLAM / BRAS? on one Mikrotik Ethernet Port?
mistry7
doush
Long time Member
Long time Member
Sat Feb 04, 2012 12:58 pm
mistry7
If both connections are going to be terminated on the same DSLAM, then on the mikrotik, the interface the PPPoE client is calling has to have a different MACs.
In simple terms, Caller-IDs has to be different. You can achieve this by having 2 ethernet cables going into different ports of the RB from the ADSL Router in bridge mode, and each interface has its own PPPoE client.
mistry7
Sat Feb 04, 2012 3:10 pm
@doush
this was the question i sent to thread-starter, i know this...
But not all people know this issue!
I have a lot of this connections on one DSLAM, like one Flatrate with Dyn-IP and one with 1 ore more Static IP´s and non flatrate!
Policy based routing etc....
mistry7
Users browsing this forum: No registered users and 80 guests
