pm2008
system error critial router was rebooted
Mon Feb 06, 2012 1:55 pm
Hello
I am using a vpn server with MikroTik OS 5.7
My previous server was 5.5 MikroTik After a few months down the problem
Its My BiG PROBLEM
system error critial router was rebooted without proper shutdown
This problem occurs every few hours
I truly did not matter how I look
Were told that the problem is hardware But I changed my server to another server and bought a data center
But this issue also came up after a few days a new server
I'm sure that's not a hardware problem and another reason is
Reasons such as an attack on the server, user misuse and vandalism that
pm2008
Re: system error critial router was rebooted
Tue Feb 07, 2012 3:03 pm
help plz:((( :(
normis
Tue Feb 07, 2012 3:20 pm
1. Upgrade to v5.12
2. Check for power problems, as the error indicates you had a power outage.
pm2008
Tue Feb 07, 2012 3:37 pm
tnx 4 answer
Possibly due to attack power to the server is in trouble?
Daniel4u
Thu Feb 16, 2012 1:41 pm
Please Answer I have this problem
What do I have to do? :?
sonny
Fri Feb 17, 2012 3:46 am
Have you upgraded firmware?
You will find under -system - routerboard / upgrade
Reset configuration after upgrade and start a new configuration from scratch.
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
cearnshaw
Sun Feb 19, 2012 2:02 am
Same problem here with every version I've tried from 5.9 to 5.13 (I'm on dual-core x-86). Went back to 5.6 and so far so good. I do have one machine running OK on 5.12, but others won't. It's a mystery to me.
At first we thought it was a power issue too, but changed out UPS and problem persisted. Then we changed version and everything OK. Happens on multiple machine at multiple sites, so it's not a power issue.
Cam
UPDATE: Still no more problems since downgrading to 5.6
Users browsing this forum: armpogart, Shy, Tdaddysimi and 65 guests
