SULTAN
Help mr.normis Fix NetCut Problem :(
Mon Feb 06, 2012 8:35 pm
Hi Ihave Problem With NetCuts same this :
http://www.youtube.com/watch?v=1WlfLCfdzlY
Ineed For Block NetCuts And Any program like it ..
How To Do That Mr.Normis Please :( :?
normis
Re: Help mr.normis Fix NetCut Problem :(
Tue Feb 07, 2012 10:17 am
use WPA encryption or PPPoE on your wireless AP. This will solve it.
SULTAN
Tue Feb 07, 2012 12:53 pm
Ok ‎‏ ‏normis but how in hotspot system?? Imeen login page ?? How
normis
Tue Feb 07, 2012 12:54 pm
you can use WPA with hotspot, no problem. Just distribute the WPA key together with login/password.
SULTAN
Tue Feb 07, 2012 1:18 pm
You Meen in wireless??
I Need The wireless Stay Open Network For Get New Customers You Know ,,
But If you Meen Another Thing Explain It Please .. Its big Problem :(
normis
Tue Feb 07, 2012 1:24 pm
You could create two access points with help of VirtualAP feature. Example:
SSID: hotspot-registration (no WPA)
SSID: hotspot-login (WPA)
when customer needs internet, they connect to hotpost-registration, register, and get login/pass/wpa key for second AP.
SULTAN
Tue Feb 07, 2012 1:32 pm
Thanks Mr.normis :) ..
But Its Maybe hard to some customers Do that ..
No any another way To do that ?? Its Big problem if mikrotik dosen't Fix It ..
normis
Tue Feb 07, 2012 1:33 pm
We are researching how to solve this.
SULTAN
Tue Feb 07, 2012 1:44 pm
I hope Fix This Problem In V 5.13 Mr.normis ..
Any One Can hack My Mikrotik System :( !
I hope you Take This Problem Seriesly
And Thanks Normis For Help :)
bambangs2komputer
Tue Feb 07, 2012 2:12 pm
for my hotspot with RB450G+ 3 AP netcut can't scaning other member hotspot because I use DHCP-server with netmask 32.but queue will limit all conection from any to any, thats solved if config mangle :-)
normis
Tue Feb 07, 2012 3:57 pm
SULTAN: Is your wireless AP from MikroTik or only the hotspot server is MikroTik? Have you actually verified that this Netcut program does what is advertised?
SULTAN
Tue Feb 07, 2012 4:09 pm
Yes Mikrotik RB450G And wireless is rb433 with 2 card wireless ..
itry that way and its work .. imeen same video ..
all my system is mikrotik no any problem ..:)
idon,t no this how advertised ??
Feklar
Wed Feb 08, 2012 12:07 am
The ONLY way to really mitigate netcut and programs like it on a hotspot is to build out your layer2 network in such a way that prevents people from being able to use these programs. There is no solution that is built into any router that will solve this for you. If you want to to block it, this means that you MUST invest in the hardware that you install that has the very features that you need and want. This question comes up very often, and the answer is always the same, invest in the layer2 network to prevent it. Get switches that either do VLANs or port isolation, dhcp-snooping, etc. Get access points that do client isolation (turn off default forwarding on MT radios) to prevent clients from talking to each other over the radio. These will put the protection at the edge of the network where it needs to be in order to prevent people from talking to each other directly. In order for a device to prevent traffic from going between hosts, it must first go over that device. Because of this a layer3 device cannot block communication on layer2, one does not need to traverse the router to talk to another host.
Handing out a /32 is very easy to get around, all I do is have to assign myself a static IP and a larger subnet, and then I can scan the network and find the IP/MAC of any machine on the network within my subnet. It also does nothing to prevent a someone from installing their own DHCP server on their machine and handing out leases on the network, or from taking over the MAC and IP of your default gateway causing problems for clients on the network, or any other number of potential intentional or accidental things that end users do with their hardware. At most it is an annoyance to someone that wants to do this, and may prevent a general user from using a program like this, but it offers no real protection at all.
normis
Wed Feb 08, 2012 8:07 am
so your hotspot is on the RB450G, and the Wireless is served by RB433?
What do you see in the Log file when the "bad" client takes over the connection of the "good" client? It would be interesting to see the wireless debug log
frnet
Wed Feb 08, 2012 12:43 pm
As discussed in the forum, the problem of using /32 netmask are generally customers with linux (and android) that can not operate without manual set (or script).
bambangs2komputer
Wed Feb 08, 2012 5:03 pm
you right, for android I use pppoe-client &database on the usermanager so config your hotspot+ppp. don't forget android your customer root pppoe-client. or you can upgrade your android becouse after upgrade my friend still conct hotspot with netmask 32
normis
Thu Feb 09, 2012 8:57 am
But if you turn off wireless "default forwarding" then Netcut can't scan for network hosts. Basically it cripples it's operation.
Also the old Netcut version used to ARP poison the victim host, but the new one (2.1.4) poisons RouterOS ARP table, which means the hotspot will also not work. Either way, I can't see how you can get Netcut to operate if Default Forwarding is turned off.
SULTAN
Thu Feb 09, 2012 2:37 pm
Ok Normis Iwill Try It And Tell You What happened ..
normis
Thu Feb 09, 2012 3:16 pm
yes! set "default-forwarding=off" on the wireless AP and check, Netcut won't be able to operate anymore.
SULTAN
Thu Feb 09, 2012 8:36 pm
Hi Mr Normis ..
I try It With Disable Default-Forwarding ..
And Still Same Problem :( ..
Look Mr Normis .. The APs Its Bridge .. No Give IP .. i have Make It DHCP server ?? The Wireless Card I mean RB433AH ..
Alessio Garavano
Thu Feb 09, 2012 9:53 pm
"default-forwarding=off" only can help to isolate clients connected on the same wireless card(AP)... to do an efficient clients isolation in a RB with more then 1 wireless AP or in a great bridged network, is needed to do this simple bridge filter rule:
/interface bridge filter
add chain=forward in-interface=!ether1-WAN out-interface=!ether1-WAN action=drop
assuming the WAN port of the RB is the "ether1-WAN"
Need to put this rule in all yours RBs... first can try with action=log ;)
Regards!
Alessio Garavano
http://www.isparg.com.ar
normis
Fri Feb 10, 2012 7:32 am
well your setup is not optimal then. yes, default forward will protect other clients on the same AP, but because you have bridge behind the AP, netcut will see some clients from other APs. you need to implement bridge firewalls, /32 addresses or some other workarounds.
Or you need to think about different type of setup, where the devices are not all on the same network.
How about hotspot servers on each AP, with a central RADIUS database? No bridge involved. Default Forward will work then.
Chupaka
Fri Feb 10, 2012 2:50 pm
the solution is simple: do not bridge xD
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
SULTAN
Fri Feb 10, 2012 4:50 pm
Mr Normis .. You Mean I have To Make The APs DHCP-Server ?
And protection Is For Client On Same AP .. Right ?
Now Any One Not online With AP Than Not Have Default-Forwarding Is No protection Right ?
I have To Set Disable Default-Forwarding And Make It DHCP-server One Any APs Right ? Or Not ?
SULTAN
Mon Feb 13, 2012 9:57 pm
http://www.youtube.com/watch?v=H-1pZ-3-ieQ
If You Finish Watch The Video Tell Me ,,
Now .. How To Fix The Problem ..><" How To Solve It ????? Please Mr.Normis
sergejs
Tue Feb 21, 2012 1:48 pm
If Netcut is huge problem in your network, follow the advice from previous responses;
- remove bridges from your network;
- setup HotSpot+DHCP on every wireless interface (do not forget to disable default-forwarding);
- setup RADIUS server to share one database between all AP in your network.
SULTAN
Tue Feb 21, 2012 1:56 pm
Mr sergejs .. Thanks For Respone ,,
OK Now .. If I Do all That .. the Problem is solve 100% ? No Any NetCuts Again ?
IS Hard to do it and Find Same Problem :o ..
SigantengKalem
Mon Apr 02, 2012 10:30 am
yogii
Sun Apr 08, 2012 8:17 am
very good topic :), then i'll bookmark. thanks for all.
Users browsing this forum: Bing [Bot], erlinden, kivimart, Majestic-12 [Bot], MarcDE and 98 guests
