darthtanion
RB751 and Sierra AirCard 320U
Fri Feb 17, 2012 4:09 am
Hi guys,
I couldn't find anything referring to this model of card specifically but hopefully someone can help out or at least tell me conclusivly that it's a lost cause. I have a Telstra 4G LTE USB dongle (Sierra AirCard 320U) that I'm trying to get to work with an RB751. I'm very new at MikroTiks (although I do have other people helping me as well) but I've been told I need to get the right info and data channels as well as the modem init string, phone and dial command. Does anybody have any info on how I would go about finding them. I've done lots of Googling and haven't gotten very far yet. Anything you could suggest would be great. Thanks.
andersm
Re: RB751 and Sierra AirCard 320U
Fri Sep 14, 2012 3:59 pm
Hi darthtanion,
Not sure if you have resolved this yet.
I have just been playing with an AirCard 320U and have had good success with one in a RB751 running 5.20
If you just create a new PPP session, you should see a new USB interface "usb2" within the new PPP session.
Select "usb2" and then set "Data Channel" to 3 and "Info Channel to 2.
I used the APN "telstra.internet"
Under the PPP tab, make sure to de-select "Dial On Demand"
Leave all the other settings as default and you should be good to go.
Hope that helps!
Users browsing this forum: armpogart, jonah1810, pe1chl, Shy, Tdaddysimi and 67 guests
