Lakis
Forum Veteran
Forum Veteran
Evry Day Kernel Failure?
Sat Feb 25, 2012 7:38 pm
after upgrade from 5.9 to 5.13
RB800 reboot 4-5 times a day
than downgrade to 5.12 but same
Any Help?
Tnx
jcem
Re: Evry Day Kernel Failure?
Sat Feb 25, 2012 8:04 pm
Hi!
Do you use bridge?
If so activate rstp on each bridge....
RGDS
dejanb
Mon Feb 27, 2012 5:54 pm
Any Help?
Tnx
Hello!
Do you have multi-CPU enabled? if so, try to disable!
I had same problem until i disabled multi-cpu support!
Regards!
honzam
Mon Feb 27, 2012 9:20 pm
what routerboot?
/system routerboard print
LAN, FTTx, Wireless. ISP operator
dejanb
Tue Feb 28, 2012 12:43 am
Hello!
Sorry, my mistake xD
I didn't saw that you are using RB800, i had same problem, but on x86 Dual Core system.
Regards!
Lakis
Forum Veteran
Forum Veteran
Tue Feb 28, 2012 1:13 am
Yes with multi core PC I was having long time ago kernel problem but I m using RB800 just for p2p Link
no special config just AP bridge<->Station WDS no firewall...
today I upgrade to 5.14 this show up bad-blocks: 0.1% (if this is the case but I m not shure)..
cearnshaw
Thu Mar 01, 2012 7:41 am
All my x-86 dual-core machines have problem with 5.x. One machine runs fine on 5.12 now, but another machine of same type will not. I put it back to 5.6 and it ran for ten days, then locked up. Had to power it down to fix it. This is very frustrating. I've been using Mikrotik since somewhere around 2002 and have been a big supporter, but lately between this and RB450G capacitor problems I am afraid I am going to start losing my customers. I wish they would be more careful with the products/versions they release. Seems like every O/S release fixes something and breaks something else. And now there is talk of V6.x? Crazy!!!
Users browsing this forum: joshfinlay, mducharme and 47 guests
