sminhaz
How to Setup Mikro Tik to be a VPN server-- PLZ help me
Fri Dec 16, 2005 9:54 pm
I have few customer they are from diff network I want to dial them to my Mikrotik and get Connected there and get IP from the DHCP POOL and i want to route all there packet from by the MIKROTIK. Like they will dial my Ethernet 0 IP address and will get connected there and make a Tunnel and after that what ever paket will be send fromt that USER that paket will will come to The MikroTik and and MikroTIK will route that Traffic / Paket to the Ethernet 1 IP address .
Can any one help me for this plz i need this help very badly.
Thanking You
Mufrad
andrewluck
Forum Veteran
Forum Veteran
Fri Dec 16, 2005 10:43 pm
Mufrad
Suggested reading:
http://www.mikrotik.com/docs/ros/2.9/
There's a whole section on configuring VPN servers and clients.
Regards
Andrew
Syonyk
Fri Dec 16, 2005 10:48 pm
Look in the manual for VPN examples.
In a nutshell, you'll want to set up a PPTP server. In the default-encrypted profile, select your IP pool for the local & remote addresses. Set up the PPP users (or authenticate against RADIUS), and they should be able to connect in. If the IP pool they connect to can normally get to the internet, they should be able to get to things normally when VPN'd in.
-=Russ=-
Users browsing this forum: Bing [Bot], DarkNate, Google [Bot], Znevna and 91 guests
