mk0000
Routing Problem
Sat Mar 03, 2012 9:24 am
i have a problem with the following Problem:
One RB 450G (IP: 192.168.0.5) with 100 PC's and 2 WAN-Ports (Port1 and Port4).
On Port1 there is a Fritzbox (192.168.0.1) and on Port4 there is a Fritzbox (192.168.0.2)
Alle LAN-Ports from the RB 450G are a bridge.
All PC's from the other LAN-Ports has the following IP-Configuration:
IP: 192.168.0.x/24
Gateway and DNS: 192.168.0.5
Route:
0.0.0.0/0 goes to 192.168.0.1
One Client (192.168.0.140) will now switch to the second-WAN-Port (Port4).
I have test it with the firewall:
Mangle:
Prerouting Src-Address 192.168.0.140 and mark routing for Example GroupB.
Then i add a Route:
0.0.0.0/0 goes to 192.168.0.2 with Routing Mark GroupB
But the Traffic goes over the Port1 (192.168.0.1).
Can everyone help me?
rodolfo
Long time Member
Long time Member
Re: Routing Problem
Sat Mar 03, 2012 11:18 am
post your configuration (ip address, ip firewall mangle, ip route)
rodolfo
IZ0UQV
mk0000
Re: Routing Problem
Sun Mar 04, 2012 1:52 pm
Hi rodolfo,
my configuration from the RB 450G:
# ADDRESS NETWORK INTERFACE
0 192.168.0.5/24 192.168.0.0 bridge1
/ip firewall mangle
0 chain=prerouting action=mark-packet new-packet-mark=connection
passthrough=yes protocol=tcp
1 chain=prerouting action=mark-packet new-packet-mark=conn passthrough=no
2 X chain=prerouting action=mark-routing new-routing-mark=GroupB passthrough=no
src-address=192.168.0.140
0 A S dst-address=0.0.0.0/0 gateway=192.168.0.2 gateway-status=ether4 reachable
distance=1 scope=30 target-scope=10 routing-mark=GroupB
1 A S dst-address=0.0.0.0/0 gateway=192.168.0.1
gateway-status=192.168.0.1 reachable bridge1 distance=1 scope=30
target-scope=10
2 ADC dst-address=192.168.0.0/24 pref-src=192.168.0.5 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
The PC's at the the LAN-Port 2,3 and 5 are at other switches and has the following configuration:
IP: 192.168.0.x/24 (x = 60 - 140)
DNS + Gateway: 192.168.0.5
Where can help me?
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 2:49 pm
set the use of IP FIREWALL on bridge to enable first,
if it didn't work then change the specific policy route's mangle chain from pre-routing to forward, too.
study the packet flow diagram will help you to make your own policy implementation decisions well.
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
Any sufficiently advanced technology is indistinguishable from magic. ( Arthur C Clarke )
Mikrotik certified consultant
Microsoft Certified Technology Specialist, Microsoft Certified IT Proffessional
http://www.netd.ir
mk0000
Re: Routing Problem
Sun Mar 04, 2012 3:12 pm
hello cybercoder,
the firewall on the brigde is enable.
When i change pre-routing to forward, it come a error-message:
Couldn't change Mangle Rule - routing-mark allowed only in output and prerouting chains.
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 3:15 pm
yes yse the error message is true the routing mark only works in routing time! i made mistake
http://www.netd.ir
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 3:17 pm
allow to pass the traffic through the router in second mangle chain, i think it will work
the second is meaning number 1 not 2
http://www.netd.ir
mk0000
Re: Routing Problem
Sun Mar 04, 2012 3:20 pm
Example?
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 3:50 pm
i mentioned to the second mangle you sent :
1 chain=prerouting action=mark-packet new-packet-mark=conn passthrough=no packet-mark=connection
change the passthrough to yes
http://www.netd.ir
mk0000
Re: Routing Problem
Sun Mar 04, 2012 7:33 pm
passthorugh is activated but the traffic goes over 192.168.0.1 and not over 192.168.0.2
Help?!
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 7:45 pm
chain=prerouting src-address=192.168.0.140 action=mark-connection new-connection-mark=GroupBC passthrough=yes
chain=prerouting connection-mark=GroupBC action=mark-routing new-routing-mark=GroupB passthrough=no
Replace mangles with these optimal mangle.
http://www.netd.ir
mk0000
Re: Routing Problem
Sun Mar 04, 2012 9:18 pm
The same Problem :(
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 9:24 pm
are there count up for your specific mangle?
http://www.netd.ir
mk0000
Re: Routing Problem
Sun Mar 04, 2012 9:52 pm
Yes, but the traffic goes over 192.168.0.1.
cybercoder
Re: Routing Problem
Sun Mar 04, 2012 9:55 pm
i am online by yahoo messenger : vahid_yid
http://www.netd.ir
mk0000
Re: Routing Problem
Tue Mar 06, 2012 10:32 am
I have test it with 5 Clients.
One Clients goes over the second Gateway all other over the first Gateway.
The Mangle-Entries count up but nothing over the second Gateway.
Is there a special Entrie or other things i have disremember?
The Config
IP-Address
Bridge
 0  R name="bridge1" mtu=1500 l2mtu=1520 arp=enabled
      mac-address=00:0C:42:59:1D:2E protocol-mode=rstp priority=0x8000
      auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
      forward-delay=15s transmit-hold-count=6 ageing-time=5m
 #    INTERFACE               BRIDGE               PRIORITY  PATH-COST    HORIZON
 0    ether1                  bridge1                  0x80         10       none
 1    ether2                  bridge1                  0x80         10       none
 2    ether5                  bridge1                  0x80         10       none
 3    ether3                  bridge1                  0x80         10       none
 4    ether4                  bridge1                  0x80         10       none
DNS
servers: 192.168.0.1,192.168.0.2
  allow-remote-requests: yes
    max-udp-packet-size: 512
             cache-size: 2048KiB
          cache-max-ttl: 1w
             cache-used: 1712KiB
Firewall Filter: nothing
Firewall Nat: nothing
Firewall Mangle:
 2   ;;;
     passthrough=yes src-address=192.168.0.140
 3   ;;;
     passthrough=yes src-address=192.168.0.94
 4   ;;;
     passthrough=yes src-address=192.168.0.111
 5   ;;;
     passthrough=yes src-address=192.168.0.112
Route
        gateway-status=192.168.0.2 reachable bridge1 distance=1 scope=30
        target-scope=10
Where is the Problem?
Is there a way for a client, gateway and DNS to change through the firewall?
cybercoder
Re: Routing Problem
Tue Mar 06, 2012 10:38 am
You should Mark the connections first, then the packets of those connection!
when you don't allow to pass the traffic in this scenario, how the next mangle rule can work?
I think i sent an optimal mangle
http://www.netd.ir
mk0000
Re: Routing Problem
Tue Mar 06, 2012 11:07 am
I have disable these two Mangle's and will test it or can i sort the Mangle's ?
Users browsing this forum: MSN [Bot] and 105 guests
