vadood
Mangle not marking connections
Tue Mar 06, 2012 10:53 am
I have this problem with mangle
I have created a mangle rules like this:
 3   ;;; Mark Hotspot Connection
     chain=prerouting action=mark-connection new-connection-mark=HotSpot_Conxn passthrough=yes src-address-list=[b]Hotspot[/b]
 4   ;;; Mark Hotspot Connection
     chain=prerouting action=mark-connection new-connection-mark=HotSpot_Conxn passthrough=yes dst-address-list=[b]Hotspot[/b]
 5   ;;; Mark HotSpot Packet
     chain=prerouting action=mark-packet new-packet-mark=HotSpot_Pkt passthrough=no connection-mark=HotSpot_Conxn
but when I look at connections, some of them are marked and some are not; this ip is in the Hotspot address list above
I do not exactly know how Mikrotik marks connections and why this happens, but I can not use queues effectively because of this.
sja
Re: Mangle not marking connections
Wed Mar 07, 2012 9:01 am
I think you need to add a "connection-state=new" to your mark connection mangle rules.
Here is an example of what I use (I use the forward chain but it will work as well on the pre-routing chain):
add action=mark-connection chain=forward connection-state=new dst-address-list=X new-connection-mark=conn-X
Hope that helps.
vadood
Wed Mar 07, 2012 10:17 am
Thank you for the hint, I will try and see the results
I want to figure out how mangle works, what happens if we do not state any connection-state= setting? will it mark all connections? will it only mark new connections? what is the default behavior?
documentation is so poor for mangle :(
Users browsing this forum: Bing [Bot], psannz and 142 guests
