Hi there,
I've been struggling to find a method to loadbalance 5x 50/5Mbps WANs whilst using RB's (at the moment using RB1100ahx2).
Not only that but I need a suitable QoS system which will work with the above.
The system will have around 60-65 users attached by a router (something like a SOHO MK or Ubnt Airrouter). So I believe using something like PPPoA/PPPoE + MAC to control access to the network using radius manager 3 (DMA soft labs).
I will be using internal IP's for the whole network and need to employ client separation to prevent snooping.
Basically I need some help, with the hardware to try and minimise the equipment needed. So could someone recommend suitable RB's or say if i need x86 system to run this.
If you can think of a better method of setting up the network to allow more efficient usage of CPU power please let me know.
