MUM Europe 2020
securex
Help with DSBL.ORG
Tue Dec 27, 2005 12:21 pm
dsbl. org is freqently putting one of our routers ( not servers ) on their list.
Here is the detail:
http://dsbl.org/listing?62.233.191.226
Could anyone help ?
I mean I removed once from thei list, but they did it again. Shoul I do something with router config ?
Regards
Peter
Tonda
Tue Dec 27, 2005 12:41 pm
Do you have mail server in your network?
sergejs
Tue Dec 27, 2005 12:45 pm
You have to restrict access to your router.
If you have proxy, modify access-list (or firewall input chain) allowing access to router only for trusted users.
securex
Tue Dec 27, 2005 1:31 pm
Yes but with other IP. This is only router with masquerade.
securex
Tue Dec 27, 2005 1:35 pm
Yes but:
1.access is restricted only for internal network
2. proxy works on port 80 while DSBL test message is sent on completely different port as You can see:
http://dsbl.org/message?30917003
Tonda
Tue Dec 27, 2005 1:48 pm
Are incoming SMTP connections dst-natted to mail server in your internal network?
securex
Tue Dec 27, 2005 1:56 pm
No. On 62.233.191.226 no service is active. Once more: it is only masquaraded address for internal network.
BTW mail server is active but at 62.233.191.168 but it requires auth to send anything
mag
Tue Dec 27, 2005 3:57 pm
if the address was part of a dial-in pool of a large ISP, its very common that it is listed in several black-hole lists.
only way to get out is getting a static ip with correct PTR-record or using a SMTP-gateway.
not exactly a router-specific problem ;-)
Eugene
Forum Veteran
Forum Veteran
Tue Dec 27, 2005 4:58 pm
Close SOCKS Proxy on the router (or at least restrict it to LAN).
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
securex
Tue Dec 27, 2005 6:09 pm
How ?
Eugene
Forum Veteran
Forum Veteran
Wed Dec 28, 2005 6:06 pm
/ip socks set enabled=no
securex
Wed Dec 28, 2005 8:34 pm
it was always disabled
Users browsing this forum: No registered users and 123 guests
