yo3gjc
Comments on 6.0b2
Sat Apr 21, 2012 1:50 am
Am I blind and cannot see NTP server or is missing? maybe is Friday and I'm too tired but I cannot find NTP server either in GUI or cli...only client
jandafields
Re: Comments on 6.0b2
Sat Apr 21, 2012 4:40 am
If it's like all the last versions, that is normal. It comes with simple client by default, but the NTP package is a file package (separate) of it's own. That's how it's been for a long time.
yo3gjc
Sat Apr 21, 2012 1:05 pm
Jeez...right, got it, tnx...yesteday was blind day, Friday :lol:
Takv2011
Sun Apr 22, 2012 4:10 am
We can see a wrong sentence: In Winbox, Ip -> DNS, says "Dyanmic Servers", instead of "Dynamic Servers".
We can find the same thing on NTP Client.
Regards
rzirzi
Mon Apr 23, 2012 7:43 am
Is there changelog for Beta2? At the: http://www.mikrotik.com/download/CHANGELOG_6 is only: What's new in 6.0beta1 (2012-Apr-13 15:26)
cupis
Mon Apr 23, 2012 12:27 pm
6.0beta2 changelog is now at the above URL.
advantz
Mon Apr 23, 2012 7:16 pm
simple queues didn't work...
Chupaka
Wed Apr 25, 2012 5:25 pm
[admin@MT] /ip neighbor discovery> export compact
# apr/25/2012 17:22:35 by RouterOS 6.0beta2
set lo disabled=yes
'lo' is bridge
after reboot, discovery is enabled again on it
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
dnyl
Fri May 04, 2012 2:52 am
What about the Vlan?
When I upgraded from 5.14 to 6.0b2 i lost my connection over vlan. The config is the same.
What is the solution?
matvej
Sun May 13, 2012 1:44 pm
IGMP Proxy working bad :(
Chupaka
Tue May 15, 2012 3:08 am
what exactly is bad? :)
janisk
Tue May 15, 2012 8:46 am
just to inform you all, we are working on new routing, that could solve some IGMP-Proxy and PIM problems that we are currently experiencing.
If you see behaviour different form 5.16 please report those.
TKITFrank
Tue May 15, 2012 9:05 am
Any update when new version of v6 will be released and when the new routing will be implemented?
MTCNA
"I don't believe UNIX is Utopia. It's just the best set of tools around."
ropebih
Tue May 15, 2012 10:26 am
In version 6 IGMP proxy with quick Leave enabled does not work at all. With quick Leave off working bad as Matvej said. After mikrotik boots it takes couple minutes that IGMP proxy start to work. Once that IGMP start to work it's still working bad, after I switch on STB from channel to channel it takes 10-20 seconds to get the picture. It's usually lasted up to 1 second.
danilosceu
Wed Aug 15, 2012 5:13 am
Hello people, I am Brazilian, here the queue tree not working, and I can not downgrade. any predictions for correction?
Chupaka
Mon Aug 20, 2012 4:05 pm
Users browsing this forum: Baidu [Spider], Bing [Bot], brixsat, ementat, greykim, svmk, upcspl and 96 guests
