makkan
3G Modem - Signal Strength?
Thu Apr 26, 2012 6:52 pm
Hi guys,
Is there any way to see the signal strength of my 2g/3g connection while ppp is running?
I'm currently on the other side of the globe and the router is having some performance issues but I can't see any signal strength without shutting down the PPP-client.
Marcus
MrYan
Re: 3G Modem - Signal Strength?
Thu Apr 26, 2012 9:32 pm
I can get it using this command on my MT:
/interface ppp-client info <3G modem interface>
makkan
Thu Apr 26, 2012 9:36 pm
Are you sure that you can do it while the PPP-client is using the modem?
What version of ROS are you using?
MrYan
Thu Apr 26, 2012 11:39 pm
The modem is a ZTE MF626 on 5.14 and I tested the command while the PPP session was up.
makkan
Thu Apr 26, 2012 11:55 pm
I'm just running version 5.8, might be some new feature. Mine just says smth like "Cannot aquire port while being used by ppp-client".
Richiep
Fri Apr 27, 2012 12:36 am
make sure the data channel and info channel are different
poxx
Wed May 16, 2012 4:01 am
You can also see this in Winbox :
-> open winbox
-> left-click "PPP"
-> left-click "Interface" tab ( default )
-> double-left-click on your 3G modem interface
-> left-click on "Info..." in right menu, almost on the bottom
-> make sure that in the "interface" option on the popup window your 3G connection is selected
-> "Signal Strength" at the bottom of the list will display your current 3G signal strength
Some general info about dBm ( in case anyone finds this post and won't know what to do with the actual values )
A 3G signal strength between -70 dBm and -80 dBm is optimal, but sometimes even on -100 or even -110 (worse) you can still get decent internet.
Lower dBm values means better 3G connection.
dreamrider
Mon Jul 30, 2012 12:13 am
@ poxx
Thanks for this great info about "dBm"! I found this "info" button, but RouterOS says - "Modem couldn't respond". Data Channel was "0", Info Channel was "1". But when I changed Info Channel to "3", info shows up! Modem type: Huawei E353, working great with ROS 5.19.
mobile4lte
Wed Aug 22, 2012 10:52 am
Huawei e355 mobile WIFI modem is a good Signal.you can external antenna.
Users browsing this forum: No registered users and 115 guests
