jarekj
transparent trafic shaper - queues question
Thu Jan 05, 2006 11:18 am
I want to use Mikrotik - OS 2.9.8 - as transparent trafic shaper.
I set up bridge (ether3 - ether4), ether 3 - inner network interface, ether4 - outher network interface.
Next, I would like to shape trafic for users connected to ether3, per IP address, for down and upstream.
So, I created queue simple for testing purposes:
0 name="test" target-addresses=111.222.333.444/32 dst-address=0.0.0.0/0 interface=ether3 parent=none direction=both priority=8 queue=default/default limit-at=0/0
max-limit=256000/256000 total-queue=default
After this setup looks like queue works for downstream but upstream is not shaped. I have no idea, why only downstream is shaped and upstream is not.
Any help will be fine.
Regards
yogi
Fri Jan 06, 2006 5:33 pm
change it to interface=all
if you were the bouncer for a club, would you stand outside or in? :wink:
Users browsing this forum: mirk, sahil32 and 191 guests
