MUM Europe 2020
dmagno
routing process 100% CPU Load intermittently
Wed Jun 13, 2012 9:13 pm
Hi!
All our RB433AH are having a strange issue.
They are intermittently with 100% load CPU, only rebooting back to normal, but sometimes she did not even respond to the reboot command in Winbox.
In the 'Tools' > 'Profiles', the process that consumes all the CPU is the 'routing process'.
RouterOS v. 5.17
Firmware v. 2.39
/system package print
# NAME VERSION SCHEDULED
0 system 5.17
1 X ipv6 5.17
2 mpls 5.17
3 wireless 5.17
4 ppp 5.17
5 routing 5.17
6 dhcp 5.17
7 routerboard 5.17
8 routeros-mipsbe 5.17
9 security 5.17
10 hotspot 5.17
11 advanced-tools 5.17
/tool profile (When operating normally)
NAME CPU USAGE
wireless all 2%
pppoe all 0%
ppp all 0%
ethernet all 0.5%
console all 0%
firewall all 2%
mpls all 0%
management all 1.5%
ldp all 0%
idle all 87%
profiling all 0%
queuing all 5.5%
routing all 0%
bridging all 0%
unclassified all 1.5%
Any ideas?
normis
Re: routing process 100% CPU Load intermittently
Thu Jun 14, 2012 11:17 am
Do you use BGP/OSPF dynamic routing in this device?
dmagno
Thu Jun 14, 2012 1:44 pm
Hi normis.
We do not use BGP/OSPF.
We've tried to disable the packet routing, and even uninstall it, but did not solve the problem.
Of the eleven RB433AH we have, these, two do not have this problem, coincidence or not, these two do not use VPLS, all others yes.
normis
Thu Jun 14, 2012 2:46 pm
please generate a supout.rif file during the problem, and email it to support@mikrotik.com along with a problem description. We will look if the file shows cause of the high usage.
ibermi
Thu Jun 14, 2012 5:22 pm
To me it is exactly the same with a RB433AH, CPU 100% of the routing, and without flowing traffic. And I do not use any routing or BGP / OSPF or VPLS. All basic configuration, I have version 5.14, and also happens to me, could be is the problem of new boards (hardware). Have if it is the solution. Thanks.
Look at the image.
miguelbatista at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Expert in Wireless, Hotspots, Linux and Radius Servers
normis
Fri Jun 15, 2012 8:47 am
I can immediatelly recommend two things, ibermi. Please upgrade RouterOS to v5.17, and also try to not use MAC address when connecting to the router. Use IP address, it's much faster and more stable.
Ibersystems
Fri Jun 15, 2012 10:05 am
Hi normis, we have the same issue with different versions in this ibermi board. We netinstalled it and we had the same problem. It's a nonsense..
We will try to upgrade to the last version and see what happens and give a report here.
thanks,
Martín
martinruiz at ibersystems.es
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
normis
Fri Jun 15, 2012 10:06 am
if the same happens in v5.17, make a supout.rif file when routing is near 100% and send to support
Ibersystems
Fri Jun 15, 2012 10:14 am
Ok, but dmagno has it in 5.17 : P!
we only have this as AP, with a bridge. Bridge with wlan and ether. Default gateay and IP in the bridge.
thanks,
Martín
normis
Fri Jun 15, 2012 10:16 am
Ibersystems, Dmagno, we have not yet received a supout.rif file, please send us for inspection.
Ibersystems
Fri Jun 15, 2012 11:08 am
We are working out today, but next week I will try to send it to you.
Martín
ibermi
Thu Jul 12, 2012 11:41 am
I tried doing a supout.rf, but no way has the CPU at 100%, and is unable to create it, leave 30 minutes more, but could not.
wiyat
Mon Feb 11, 2013 11:48 pm
Ibermi, how you correct this problem ... Because I have the same on one AP.
Users browsing this forum: No registered users and 96 guests
