nissandata
recomendations on VPN-tunnel btwn offices
Wed Jun 20, 2012 7:36 pm
Have a costumer with 100+Mbit/s internet on to diffrent offices, both with rb700-series routers.
What VPN-tunnel do you recomend to run between the offices.
Setup
Both sites running PPTP-vpn for roadwarriors (on mikrotik routers)
Both sites has several static WAN adresses
The sites has diffrent local subnets
Not alot of end users, about 10 at each office.
Link to mikrotik documentation or configuration examples appreciated, going to do the setup in the weekend, so just have tomorrow to test it.
cbrown
Trainer
Trainer
Re: recomendations on VPN-tunnel btwn offices
Wed Jun 20, 2012 8:56 pm
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
nissandata
Wed Jun 20, 2012 9:19 pm
Thanks, will look in to those and also http://wiki.mikrotik.com/wiki/Manual:IP ... Sec_Tunnel
The routers we use is RB751G-2HnD and RB750GL. They have quite limited hardware recourses, do you think one or the other can reach an early throughput limit considering that there are around 100Mbit available between the routers?
cbrown
Trainer
Trainer
Wed Jun 20, 2012 9:26 pm
I would not recommend using IPSec with the 700 series boards. You will not get anything near your 100mbit connection. Stick with PPTP or L2TP. If you need IPSec you should get two RB1100AHx2.
C.Brown
nissandata
Wed Jun 20, 2012 9:29 pm
Thanks a lot for the input, important notice. Good to know for the future.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], MSN [Bot] and 104 guests
