MUM Europe 2020
WirelessRudy
mipsle firmware upgrade 5.17 and higher
Tue Jun 26, 2012 11:52 am
The webpage gives two versions: adm5120-2.18.fwf and rc32434-2.18.fwf.
Are they the same?
Because I usually upgrade fw together with the ROS so all my routerboards have latest fw. But both rb5xx as rb1xx series have 2.18 installed and I use the same packages for these while upgrading.
If either one of the above mentioned fw's are uploaded to either rb5xx or rb1xx the system / routerboard / pr command shows they are already running version 2.18.
So I don't understand why the upgrade webpage has 2 different fw version where in the normal upgrade packages it looks like all mipsle have the same firmware?
Please some explanation.
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
honzam
Re: mipsle firmware upgrade 5.17 and higher
Tue Jun 26, 2012 3:55 pm
adm5120-2.18.fwf is for rb112, 133, 192
and
rc32434-2.18.fwf is for rb532
LAN, FTTx, Wireless. ISP operator
WirelessRudy
Tue Jun 26, 2012 10:09 pm
and
Well, that is already said so on the webpage. But it doesn't answer my question: Are they the same or not?
Rudy R. Puister
honzam
Tue Jun 26, 2012 10:53 pm
Both are version 2.18 but each for a different processor. So they are not the same
WirelessRudy
Wed Jun 27, 2012 1:23 am
So, if I install a normal mipsle 'routerboard' package it has both versions embedded? And the software/routerboards knows which one to pick?
I mean, if I normally install a mipsle unit the package are the same, regardless which type of mipsle routerboard I have....
Rudy R. Puister
Users browsing this forum: No registered users and 82 guests
