jguemes
DHCP after-10-secs-dely doesn't work as expected?
Tue Jun 26, 2012 12:31 pm
Hi:
I've two dhcp servers on the same subnet, server 1 with authoritative=yes option and server 2 with authoritative=after-10sec-delay option.
I can see that when dhcp client issues the dhcp discover, both servers answer with dhcp offer, at the same time.
But according to User Manual, I should expect answer from server 2 10 secs. after, and if there isn't any answer from server 1.
Even if I disconnect server 1 from network, server 2 answers his dhcp offer as soon as dhcp discover is seen.
¿Is it working properly?
Thanks.
J. M. Güemes
jandafields
Re: DHCP after-10-secs-dely doesn't work as expected?
Tue Jun 26, 2012 5:42 pm
Hi:
Thanks.
J. M. Güemes
No, it should wait 10 seconds as expected. If you are sure you have this setting enabled, and it isn't delaying, then you have found a bug. Please email this to support@mikrotik.com if you are already using the newest version.
Users browsing this forum: Baidu [Spider], gotsprings, hendra, mylos, ruwerra, SiB, Wangz, Znevna and 82 guests
