MUM Europe 2020
genaro
2.4 Ghz Wireless for outdoor.
Wed Jun 27, 2012 7:55 pm
Dear Friend's,
I want to use MikroTik 2.4 Ghz wireless link for outdoor. is the 2.4 Ghz wireless link is reliable to use in outdoor offshore/onshore for 1 KM LOS distance.
if is reliable what type of MikroTIk 2.4 GHz you will recommend.
pls. kindly advice.
Regards,
Gen
cbrown
Trainer
Trainer
Re: 2.4 Ghz Wireless for outdoor.
Fri Jun 29, 2012 3:28 pm
What are you wanting to use the wireless for?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
syadnom
Fri Jun 29, 2012 6:50 pm
That is to far for BYOD, the clients radio won't be powerful enough to reply at 1km and you can't get a large enough antenna to make it work.
genaro
Fri Jun 29, 2012 6:54 pm
I will use it for one 5MP IP Camera. and the 2.4 Ghz should have protocol for Multicast and unicast.
genaro
Fri Jun 29, 2012 7:00 pm
i will use two 15Dbi parabolic antenna PTP for 2.4Ghz wireless link.
gcs
Fri Jun 29, 2012 7:05 pm
With LOS it should work fine. If the offshore is stationary then a grid or yagi should be great. If it is movable like a boat then a sector or Omni would work. Any Mikrotik Router board would work. Make sure you get one with a AP license Level 4 for the shore side.
The best solution would be have a CPE on the remote end and an AP there to rebroadcast.
genaro
Sat Jun 30, 2012 10:54 pm
Thank gcs,
Is a fixed PTP link for IP Camera. I will use RB711-2HnD with Dual polarization of Grid antenna or disk antenna.
Mikrotik RB711-2HnD has a Multicast and Unicast protocol?
Users browsing this forum: 0pl0pl, jasons6930, pattone and 128 guests
