MUM Europe 2020
slech
Long time Member
Long time Member
SSTP VPN - Skype sound drops issue
Thu Jun 28, 2012 4:50 pm
I have setup SSTP tunnel to our USOffice.
Now we expect issue with sound drops in Skype. It seems that Skype connect to peer via SSTP tunnel.
D:\Users\admin\Desktop>type CHANGELOG_5 | find /I "sstp"
*) sstp - improve initial handshake to better handle many new connections;
*) sstp - fixed connection idle time reporting;
*) sstp - made it working on Pentium 4 again;
certificate validation problems for some programs (VPN, SSTP etc)
*) sstp - added RC4 cipher support to fix interoperability issues
*) sstp client - added an option to skip
*) sstp - when server certificate verification is enabled for sstp client,
*) sstp - fix problems on multicore systems;
*) sstp - fixed memory leak;
*) fixed sstp memory leak;
*) sstp - made it work with Windows 7;
*) sstp server - client reconnects did not work;
*) fixed sstp on x86;
*) added support for SSTP protocol (PPP over TLS);
Early we had Netscreen NS50 with IPSec setup to our RB1200, but we changed it to RB433UAH and RB1200 to RB1100AH.
Now is: RB433UAH -- SSTP -- RB1100AH.
When I drop VPN all seems to be ok. I will try to setup IPSec VPN instead of SSTP.
Does someone have similar issue ?
sorry for my english
samsung172
Re: SSTP VPN - Skype sound drops issue
Thu Jun 28, 2012 11:43 pm
try ip firewall connection tracking and set udp timeout to a higer value (20?)
slech
Long time Member
Long time Member
Tue Jul 03, 2012 1:52 am
It seems that with IPSec between offices issue disappeared. But with IPSec we have less throughput.
More good sound with lees throughput :)
mrz
Wed Jul 04, 2012 1:26 pm
Please contact support with detailed description of the problem and supout file generated at the time when problem appears.
slech
Long time Member
Long time Member
Fri Jul 06, 2012 4:44 pm
Ticket#2012070666000456
It seem that IPSec doesn't resolved issue.
slech
Long time Member
Long time Member
Mon Jul 09, 2012 3:48 pm
/ip firewall connection tracking set udp-timeout=20
Will see the results.
slech
Long time Member
Long time Member
Mon Jul 09, 2012 4:05 pm
Without success :(
How I can troubleshoot this ?
samsung172
Tue Jul 10, 2012 12:16 am
what is ping between sites? Try even bigger udp timeout. how about 50? 100?
slech
Long time Member
Long time Member
Tue Jul 10, 2012 10:57 am
Reply from 192.168.13.1: bytes=32 time=170ms TTL=63
Reply from 192.168.13.1: bytes=32 time=168ms TTL=63
Reply from 192.168.13.1: bytes=32 time=169ms TTL=63
Reply from 192.168.13.1: bytes=32 time=167ms TTL=63
Reply from 192.168.13.1: bytes=32 time=171ms TTL=63
Reply from 192.168.13.1: bytes=32 time=172ms TTL=63
Reply from 192.168.13.1: bytes=32 time=187ms TTL=63
Reply from 192.168.13.1: bytes=32 time=345ms TTL=63
Ping statistics for 192.168.13.1:
Packets: Sent = 59, Received = 59, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 167ms, Maximum = 531ms, Average = 202ms
how about 50? 100?
Will try
slech
Long time Member
Long time Member
Tue Jul 10, 2012 12:38 pm
As a workaround
Define L7 filter for Skype-to-Skype
/ip firewall layer7-protocol add comment="Pattern for: Skype to Skype traffic" name=Skype-to-Skype regexp="^..\\x02............."
Mark Skype-to-Skype traffic using L7 filter
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Skype-to-Skype packets" disabled=no layer7-protocol=Skype-to-Skype new-routing-mark=skype-to-skype passthrough=yes src-address-list=US-Skype-issue
Route Skype-to-Skype traffic via default gateway - not via SSTP VPN
add comment="Route: Skype-to-Skype via default gateway" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=81.81.81.81 routing-mark=skype-to-skype scope=30 target-scope=10
slech
Long time Member
Long time Member
Tue Jul 10, 2012 3:59 pm
Doesn't helped.
I disabled all UDP traffic in forward chain between offices.
Without success.
Only when I disable routes from each office to another issue disappeared, because then Skype doesn't have route to another office via VPN.
slech
Long time Member
Long time Member
Wed Jul 11, 2012 10:40 am
I'm trying to roll-back to ROS 5.14 both routers.
slech
Long time Member
Long time Member
Wed Jul 11, 2012 11:08 am
After downgrade to ROS 5.14 certificate disappeared from ROS and I can't import it again:
# certificate import file-name=vpn.domain.com.key
passphrase: ***************
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
Ticket#2012071166000339
Can't import the certificate in ROS 5.14, ROS 5.15, ROS 5.16.
ROS 5.17 - works. Will see what is happening in ROS 5.17 with Skype in SSTP VPN.
slech
Long time Member
Long time Member
Wed Jul 11, 2012 3:09 pm
ROS 5.17 SSTP VPN
Jitter measure via SSTP VPN
D:\>iperf -c 192.168.1.1 -u -b
iperf: option requires an argument -- b
Client connecting to 192.168.1.1, UDP port 5001
Sending 1470 byte datagrams
UDP buffer size: 8.00 KByte (default)
[1868] local 192.168.2.1 port 28498 connected with 192.168.1.1 port 5001
[ ID] Interval Transfer Bandwidth
[1868] 0.0-10.0 sec 1.25 MBytes 1.05 Mbits/sec
[1868] Server Report:
[1868] 0.0-10.1 sec 1.25 MBytes 1.04 Mbits/sec 13.252 ms 0/ 893 (0%)
[1868] Sent 893 datagrams
Jitter measure via directly
D:\>iperf -c 81.81.81.81 -u -b
Client connecting to 81.81.81.81, UDP port 5001
[1868] local 192.168.2.1 port 28627 connected with 81.81.81.81 port 5001
[1868] 0.0-10.0 sec 1.25 MBytes 1.05 Mbits/sec 0.166 ms 0/ 893 (0%)
Why jitter is so gib in VPN ?
Problem: Jitter
Understanding Jitter in Packet Voice Networks (Cisco IOS Platforms)
QoS
VoIP Basics: About Jitter
glucz
Wed Jul 11, 2012 9:43 pm
Instead of SSTP try L2TP with and/or without IPSec.
Geza
slech
Long time Member
Long time Member
Tue Jul 31, 2012 7:06 pm
Now issue appear without VPN also.
slech
Long time Member
Long time Member
Wed Mar 06, 2013 2:50 pm
1. Upgraded all devices to 5.24
2. Removed bridge(lan+wlan)
And now all is fine.
Users browsing this forum: lehomi and 99 guests
