MUM Europe 2020
rviteri
RB750UP grounded?
Mon Jul 02, 2012 7:30 pm
Is the RB750UP grounded at the ethernet ports?
Regards,
mgutz2
Re: RB750UP grounded?
Mon Jul 02, 2012 8:57 pm
yes
InoX
Tue Jul 03, 2012 1:01 am
It has shielded UTP ports but is not grounded.
normis
Tue Jul 03, 2012 10:28 am
I would like to clarify a terminology misunderstanding. "Grounded" means "connected to building grouding infrastructure through a grounding wire". Device can't be "grounded" out of the box, you have to connect it to some grounding installation. As the RB750UP has shielded ports, this means you can use Shielded Ethernet cable, and connect the shield to a grounding installation. Please see more informationin this page: http://wiki.mikrotik.com/wiki/Manual:Grounding
Users browsing this forum: No registered users and 94 guests
