MUM Europe 2020
KuwaK
Sector Writes on RB751G-2HnD
Mon Jul 02, 2012 7:36 pm
Hi everybody
I have a question about sector writes on RB751G-2HnD.
I just bought this new router for a day, but the sector writes had increased to 125939...
It increased about 600 per hour.
I did not enable web-proxy. And I set log, graph not to store on disk.
I have plugin a 16GB usb disk for SMB.
I thought that I had misconfigured something..
So I load to default but it is the same result.
BTW I am using v5.18.
Has anyone got the idea?
I had RB450G for the similar configuration. But only 255 writes for 29days of uptime. RB450G is v5.12.
Does that means I need to downgrade RB751G-2HnD to v5.12?
Now that I am afraid of killing the flash, so I had to turn off the my new router:(....
KuwaK
Re: Sector Writes on RB751G-2HnD
Wed Jul 04, 2012 5:47 pm
I restore to the default, and /sys check-disk ... nothing helped..
The sector writes still increased about 600+ per hour.
Is there Anyone using RB751G-2HnD? What is your sector writes?
Or any advice?
DBob
Sun Jul 22, 2012 2:02 pm
I have a RB751U-2HnD, and I also affected by this problem.
I cannot decrease the writings anymore, but there is still some intensive flash writing in the background...
buckett
Mon Jul 23, 2012 10:31 pm
I've got a RB751G-2HnD and after 15 days of uptime I've got 714 393 sector writes.
biomesh
Mon Jul 23, 2012 11:52 pm
I see around 8.3 sector writes per second (on average). This is around 500 writes per hour. This 751G is used only as a basic AP for about 4-5 clients. I have not seen the high flash utilization yet, but this is more utilization than my 450G with graphing enabled.
chlp
Fri Nov 02, 2012 8:37 pm
My RB writes 32 sectors every 5 min. But graphing, dhcp, etc is off.
Ham
Sun Nov 04, 2012 11:00 am
Its always been quite high for myself, my 751 is usually pretty busy.
PastuhMedvedey
Wed Dec 26, 2012 11:39 am
I had a similar problem on devices RB751 and RB2011.
The problem was resolved after the upgrade all devices to version 6.0 Rc6 firmware - 3.02. Updating is done using netinstall.
RB751U-2HnD, RB2011LS, RB1100AH, RB433, RB411GL, RBSXT, CCR1016
chlp
Sat Jan 05, 2013 11:07 am
Writes to disk reduced very good!
Users browsing this forum: Google [Bot] and 118 guests
