Roy
RB800 Factory Default
Wed Jul 04, 2012 8:44 am
How to set RB800 Factory Default?
rzirzi
Re: RB800 Factory Default
Wed Jul 04, 2012 9:02 am
http://wiki.mikrotik.com/wiki/Manual:Co ... Management
Command name: /system reset-configuration
Roy
Wed Jul 04, 2012 9:07 am
If I cannot access to RB800 with winbox, how can I do?
Setting is mixed, so I cannot access to IP address.
Can I use Reset Button? how?
Or can I use Serial port to input command?
janisk
Wed Jul 04, 2012 9:28 am
yes, this command can be used in CLI no matter how you open it. Also, in user manual you can find reset hole that will wipe the configuration from the device. But that is - if you have physical access to the router (similar to serial console cable)
Users browsing this forum: arkos, mohkhalifa, ranjeet9393, xiaotuzi and 164 guests
