tatianab
RB750UP with 3G USB modem
Sat Jul 07, 2012 8:44 pm
Hi, im trying to use a 3g USB modem on the USB port of a RB750UP but is not working. i get an IP from the USB modem on the RB 750 but when i try to ping to any address on internet the RB 750 loses the IP so i have no internet connection.
jandafields
Re: RB750UP with 3G USB modem
Sun Jul 08, 2012 7:06 pm
Send modem make and model to support@mikrotik.com to see if they can add support for that modem.
tatianab
Mon Jul 09, 2012 6:35 pm
jandafields, thanks for your answer.
But is there any configuration that i have to consider when connecting the 3G USB modem?
jandafields
Mon Jul 09, 2012 8:32 pm
I don't know, because that modem is not listed on the "supported hardware" page... so there is no way to know if it requires anything special without just playing around with it.
el berto
Fri Oct 05, 2012 10:06 pm
But when I insert USB modem in USB connector (I can see the modem on /system resources usb) but I have no new port in /system ports, does this mean my USB modem is not supported?
Thanks.
jandafields
Sat Oct 06, 2012 3:40 am
Thanks.
Probably. You should email support with supout.
el berto
Mon Oct 08, 2012 5:38 pm
But have I to see a new PORT regardless the usb modem is supported..... or only with supported USB (3G) modems?
The same regardless the routerboard model?
I mean, on RB751G-2HnD could I see the new port (full USB functions supported), but not in RB411GL?
In fact I'm trying to check if my ONDA USB UMTS modem is supported on my RB411GL board...
ditonet
Forum Veteran
Forum Veteran
Mon Oct 08, 2012 11:43 pm
From my experience, if modem is unsupported is visible on '/system resources usb',
but no new port in '/system ports'.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
Users browsing this forum: No registered users and 70 guests
