MUM Europe 2020
WirelessRudy
Speed limit per connection in simple queue? Help please.
Thu Jul 19, 2012 11:15 am
I want to setup simple queue to have each new connection (browsing) start with full speed and than after some threshold each connection steps down to lower speed (to prevent file download proceed at high speeds = occupying network for long time)
I try to set DST.Address in simple queue/advanced to 0.0.0.0/24 but it slows everything down.
I tried 0.0.0.0/30 and that also slows everything down after threshold.
How to make it to only slow down certain connection (with unique remote IP:port setting)?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
n21roadie
Re: Speed limit per connection in simple queue? Help please.
Thu Jul 19, 2012 12:29 pm
Not sure if we are looking for the same but I am looking for dynamic bandwidth script which will ignore typical browsing but will give a client for example 7Mb for 15mins (this for normal updates ?), then it will reduce to 3Mb and after 30mins of continuous downloading the speed will reduce to 1Mb and this script is active only during peak usage hours 5 to 11pm daily. I would like help on this.
http://forum.mikrotik.com/viewtopic.php ... +bandwidth
N21roadie,
Network 100% MT for Now?
Users browsing this forum: No registered users and 73 guests
