MUM Europe 2020
rgpmikrotik
linux in mikrotik
Thu Jul 19, 2012 10:55 pm
Is possible to install linux in a routerboard? I have used openwrt with metarouter but I'm asking if I can install linux as if the routerboard would be a pc.
thanks in advance
normis
Re: linux in mikrotik
Fri Jul 20, 2012 8:02 am
Possible, but not very simple. For some RouterBOARD models there are ready made OpenWRT builds, check their site.
elgo
Fri Jul 20, 2012 2:36 pm
Wrong.
There is no "ready made" builds as no mikrotik hardware is "officially" supported by OpenWRT by now.
If you have some luck, some models are in the "work in progress" state, and may really be usuable "out of the box" (like 450G).
The good point is, if you have some linux background, thanks to the good openWRT documentation you can generate your own openwrt initramfs image and netboot it very simply to test openWRT without doing any harm to your current system.
RB450G - OpenWrt (so much more stable than with routerOS)
-> now: UBNT EdgeRouter Lite
(very unlikely to be MT customer again in the future)
normis
Fri Jul 20, 2012 2:41 pm
Users browsing this forum: No registered users and 133 guests
